power recaro wiring vs. manual seat? two extra wires.
Posted: Tue Dec 28, 2004 11:24 am
they have slightly different connectors than in manual seats. the green is the same and the red is the same exept it has a red wire witch manual seat does not have.
yellow connector is different with one extra brown wire in the recaro.
I read that the yellow one is for airbags, so its a bit different than in manual seat with airbacks.
the red one might be the power controls so I guess it needs 12V for the red wire? manual seat had only one brown wire on the red plug.
the green one is same on both so that must be the heater unit.
I also measured the weight difference and to my suprise the manual ones were only 7 kilos lighter ~13lbs? 22kilos vs. 29kilos.
