Hazard indicator switch
NortheastS4
Post by NortheastS4 » Wed May 19, 2004 11:09 pm
Can anyone help? i just found the hazard button seems to have stopped working, although the button does still seem to activate as when it is pushed once the indicator stalk stops working and it starts to work ok when pushed a second time.
The indicators still flash when the car is locked and when the indicator stalk is used, but the hazards don't. There isn't even a click from a relay...
Could this just be a faulty relay or something worse??? The fuses are ok.
Where do i start???
DaveP
Post by DaveP » Thu May 20, 2004 10:31 am
Sounds like the relay to me....I think someone else had the problem recently...try a search on here...
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
excursion
Post by excursion » Sun May 23, 2004 3:34 pm
I've got a spare unit - the relay is integrated with the switch.
NortheastS4
Post by NortheastS4 » Mon May 24, 2004 11:09 am
Well the strangest thing happened, i decided to dig in to this problem yesterday, and after i pulled the stereo i tried it once more only to find the hazards working again!!!
the only thing i can think of is there must have been a loose wire in there which i've disturbed...
Put the stereo back in and its still working, so i think i'll leave it alone for now!
naz
Post by naz » Tue Aug 31, 2004 11:29 pm
Sounds like it could be the realay mate i would start with that, it should tell you whicth one it is on the fuse box cover try changing it with one from someone else's car (the same make of car!) see what happins?.
peterb
Post by peterb » Wed Sep 01, 2004 11:52 am
naz wrote:Sounds like it could be the realay mate i would start with that, it should tell you whicth one it is on the fuse box cover try changing it with one from someone else's car (the same make of car!) see what happins?.
Err... but the relay is built into the back of the switch - it isn't in the fuse box.
Suzuki Carry 660
Morpheous
Post by Morpheous » Tue Nov 30, 2004 3:51 pm
Loads of these flasher units fail, simple fix of changing hazard switch.
Flasher unit built into the back of hazard switch.
Return to “Electrical”
