Page 1 of 2
TV Screen...
Posted: Thu Feb 05, 2004 12:46 pm
by Alan
Does anyone know how to enable the TV screen in an RS6 whilst on the move?
I ask as I want to fit a DVD player in the glovebox for the other half to amuse herself with whilst on a journey, surely it must be possible using VAG-com or something? [img]images/graemlins/confused.gif[/img]
My installer tells me that normally the patch lead supplied does this but on Audi's it doesn't?
Re: TV Screen...
Posted: Thu Feb 05, 2004 12:51 pm
by bjacks
I believe you need to put a switch in the GALA circuit (the one that tells your nav that you're moving at a certain speed). This will prevent the NAV from working but you'll be watching a DVD anyway.
I think I read it on
TVWIZ.NET
Ben
Re: TV Screen...
Posted: Thu Feb 05, 2004 1:51 pm
by peterb
Certainly it is the speed signal which needs to be disconnected to enable picture whilst on the move. This will also disable the GALA facility. I don't think it will stop the Nav from working, but it may render the dead reckoning somewhat suspect. Dead reckoning should allow the Nav system to function for a while in the absence of satellite reception. The Nav+ apparently incorporates gyros to support DR, and may possibly use the speed signal to supplement to gyro data.
Re: TV Screen...
Posted: Thu Feb 05, 2004 3:42 pm
by Alan
Hmmm.
Thanks guys, so if I understand correctly, the speed signal needs to be turned off.
Would this be a permanent thing i.e. all the time or is there a way of doing it ONLY when using the TV or DVD?
Thanks for the link Ben, I'll have a trawl over there [img]images/graemlins/boots.gif[/img]
Re: TV Screen...
Posted: Thu Feb 05, 2004 4:01 pm
by Alan
Excellent, found just what I was looking for at TVWIZ...cheers chaps! [img]images/graemlins/jump.gif[/img]
Re: TV Screen...
Posted: Fri Feb 06, 2004 10:31 am
by bjacks
Let us know how you get on as it's something that I may be interested in [img]images/graemlins/wink.gif[/img]
Ben
Re: TV Screen...
Posted: Fri Feb 06, 2004 11:59 am
by Alan
Will do!
Re: TV Screen...
Posted: Fri Feb 13, 2004 12:56 pm
by dog
In the RS4 the GALA wire is a white and blue wire that is in position 1 in a black 8 pin plug.
Re: TV Screen...
Posted: Fri Feb 13, 2004 5:11 pm
by bjacks
Might you have you put a switch in yours then? [img]images/graemlins/wink.gif[/img]
Re: TV Screen...
Posted: Sat Feb 14, 2004 12:19 am
by S4 OXON
Just found a site which may help all tho its for a A2 [img]images/graemlins/confused.gif[/img]
www.audi-a2.co.uk/tvlock.pdf hope it helps a bit [img]images/graemlins/thumbs.gif[/img]
Re: TV Screen...
Posted: Thu Feb 19, 2004 10:05 am
by dog
I am going to do it in 3 weeks, when I get home from my exile....
Posted: Thu May 20, 2004 5:35 pm
by Joules
I did this to my RS and it was OK but I lost the ETA details on the Sat Nav+ and gained an error on the instrument cluster that meant the top part of the DIS did not show track info etc. Hence I have now re-connected as per std. You could use a switch but I reckon the error need a power off reset to clear??
Posted: Sun May 23, 2004 4:22 am
by dog
I have done it on mine, put a switch into the gala wire and it is working fine.
Posted: Sun May 23, 2004 9:41 am
by Joules
dog wrote:I have done it on mine, put a switch into the gala wire and it is working fine.
I must have cut the wrong wire ..... Opps
Posted: Sun May 23, 2004 10:23 am
by Scotty
On after market head units there's normally a cable to the handbreak switch. Have you tried driving with this up a notch to see if it still works? If so you can then disable this cable and still have all the other functionality.
