Page 1 of 2
dvd player for oem tv
Posted: Sun Jan 19, 2003 12:49 am
by rs4steve
phil/bushy is it possible to link an aftermarket dvd player to factory fitted tv if so what would you recomend ?
cheers steve
Re: dvd player for oem tv
Posted: Sun Jan 19, 2003 12:55 am
by PhilT
I think there is an input somewhere. I think it's in the boot, so I would consider getting portable DVD and putting it in the center armrest in the back. Slide out with it's own screen, and feed OEM TV. You can get power from the rear 12v outlet.
Sounds like a damn good idea to me.... [img]images/graemlins/smile.gif[/img]
Posted: Sun Jan 19, 2003 12:57 am
by rs4steve
thanx
Posted: Sun Jan 19, 2003 12:44 pm
by Bushy
yep in rear of sat nav in boot
uses std av connectors
Posted: Sun Jan 19, 2003 12:52 pm
by PhilT
So what do you think to my idea Steve? Sounds cool.
Posted: Sun Jan 19, 2003 12:56 pm
by Bushy
soz
only if u have sat nav plus is wot i meant
Posted: Sun Jan 19, 2003 9:24 pm
by Carl
Hi! i´m using a panasonic dvd, fitted in the rear left and connected to the tv module via rgb. theres is an infrared eye in the front for the remote. works perfect.
Posted: Mon Jan 20, 2003 1:33 am
by rs4steve
does playstation work on same setup?
Posted: Mon Jan 20, 2003 10:07 am
by Bushy
yep
well any input you like really
even a laptop! although the screen would be smaller than the laptop itself!!!
Posted: Mon Jan 20, 2003 10:10 am
by PhilT
I use an input for my video camera. Some people have a reversing camera. As Bushy says, just about anything.
Posted: Sat Feb 01, 2003 11:00 pm
by Riz_RS4
So in theory if i had a S3 with Sat Nav+ that the Unit in the boot has inputs for audio/video on them too?
What connections does it have? rgb? svhs? phono`s?
And how do you select the input from the front?
Cheers for the info [img]images/graemlins/smile.gif[/img]
Posted: Sun Feb 02, 2003 8:49 am
by Bushy
Riz
connection is RGB
I guess you must have an aux connection, unless when it senses a signal it accepts that
ANyone who has done this?
Posted: Sun Feb 02, 2003 10:34 am
by Riz_RS4
I dont actually have a TV in my S3 [img]images/graemlins/frown.gif[/img]
But obviously going to look into this when i get my next one [img]images/graemlins/smile.gif[/img] RGB is good indeed [img]images/graemlins/smile.gif[/img] could even hook my xbox up to it [img]images/graemlins/smile.gif[/img] wow!
I could well run some extended RGB cables all the way from the back to the front under the car mats and into the glove box [img]images/graemlins/smile.gif[/img]
Posted: Thu Feb 13, 2003 2:12 am
by boff
Hi Chaps
I've just stuck a DVD player in the boot and plugged into the SatNAV Plus box in the boot (or TV module combined). The Input Connectors are as follows:
1* Stereo RCA Pair (Audio Red+Black)
1* RCA Composite Video in (Yellow)
1* SVideo in
You need to use either the Composite Video or SVideo. You can't use these inputs together.
Hope this helps - btw nice forum
Best Regards
Posted: Thu Feb 13, 2003 6:57 am
by Bushy
hi boff welcome here mate
hope all is well
