RNSE / IMA+ / AMI - possible?
Posted: Mon Jan 12, 2015 4:30 pm
Hi guys
I currently have a led rnse with kufatec IMA+ (using both inputs - one for apple TV and one for auto-switching reverse camera).
I would like to also fit AMI - but of course the IMA+ is already using the AV connector socket on the back of the RNSE. Does anyone know if it is possible to have the combination I want? I guess it would mean buying the AMI and fitting the pins from one connector into the other (perhaps IMA pins into the AMI AV connector).
The same applies for the AV input - I'm hoping that can be added by simply adding the pins for L/R/common G into the AV connector (I haven't checked but am hoping they're not in use by the IMA).
Anyone have any input?
