Blackberry and Phone Book
Posted: Sat Feb 15, 2014 2:12 pm
by liffy99
Having trouble understanding pairing of my two mobiles to MMI 2g High.
I've paired both my Apple IPhone 4 (personal) and Blackberry Curve (work) to the car. Both are identified as Bluetooth devices and I can connect to both. I've imported the contacts from the Iphone into the Directory. But cannot do the same for the Blackberry - the option is just greyed out. Similarly I cannot access the phone book on the Blackberry when it is connected - all the options are still greyed out except Directory.
When connected, the Blackberry tells me that SAP is running but the ONLY option I have on the 'phone then is to disconnect !
I also thought I could create Profiles )in this case a work one and a personal one) but cannot see the option anywhere - is it possible on 2G ? Didn't help having an MMI 3g manual for a 2g car !
That probably explains why I can only have 160 Directory entries and not the thousands I thought . . .
Help appreciated
Re: Blackberry and Phone Book
Posted: Sun Feb 16, 2014 11:16 pm
by liffy99
Aha, success . . . Well, maybe.
Started again from scratch but this time ;
1) deleted call logs for phone calls and missed calls on the BB
2) paired but using hands free option with the 4 digit pin code
3) continued reading the manual in despair, then, a few minutes later, the phonebook option appeared under Memory.
Now, I don't know if that means I'll need to wait several minutes each time I start off in the car, but will soon see.
Posted: Sun Mar 09, 2014 1:01 pm
by liffy99
Doh !
Hat to make sure the Blackberry was set to 'trust' the Audi . . . All OK now.
