B7 S4 Power Seat Fuse?
Posted: Mon Jun 24, 2013 7:09 pm
by teletubby
Hi,
The driver's seat has stopped working and nobody (even main dealer!!) seems to know where the fuse is?
It's not in the normal fuse panel is as much as I know, anybody here got any ideas please?
Thanks in advance.
Re: B7 S4 Powers Seat Fuse?
Posted: Mon Jun 24, 2013 7:15 pm
by Batfinnk
Have you looked in the owners manual?
Plus if I'm right there are two fuse boards?
Posted: Mon Jun 24, 2013 7:18 pm
by teletubby
Yes, had a look, no help at all.
Where might the second fuse board be?
Posted: Mon Jun 24, 2013 7:21 pm
by Batfinnk
I think it is either under the bonnet or behind the glovebox. I just looked through my manual and the closest fuse I could see would be number 38. Your right though, none listed for the seat power specifically. Have you had a look and checked the seat plugs are still connected?
Posted: Mon Jun 24, 2013 7:32 pm
by teletubby
As far as I can feel it's still connected. Is there more than one connector?
Posted: Mon Jun 24, 2013 7:37 pm
by Batfinnk
I think there are quite a few plugs under each seat plus under the carpet under the passenger seat there are some modules too!
Re: B7 S4 Power Seat Fuse?
Posted: Mon Jun 24, 2013 7:39 pm
by teletubby
Aah, thanks, I'll go and have another look.
Posted: Mon Jun 24, 2013 8:53 pm
by teletubby
Can't see (or feel) any loose wires or find any other fuses.
Looks like it's off to let the local specialist take a look. :(
Posted: Mon Jun 24, 2013 9:36 pm
by Batfinnk
Check fuses 44 and 45. Does the passenger seat still work and do you have heated seats?
Posted: Mon Jun 24, 2013 9:42 pm
by Batfinnk
Just did some searching and found out there are some fuses and relays hidden behind the lower dash trim on the drivers side and there are fuses there for the seats.
Posted: Mon Jun 24, 2013 9:54 pm
by teletubby
Checked and both fine.
Yes, passenger seat works fine and no, I don't have heated seats.
Any idea how the lower dash trim come out / I can get access?
Thanks very much!
Posted: Mon Jun 24, 2013 10:00 pm
by Batfinnk
Not too sure how the dash panel comes off tbh. Try using the search on here. It is very useful at times :thumbs:
Posted: Mon Jun 24, 2013 10:03 pm
by teletubby
cool, thanks.
Posted: Mon Jun 24, 2013 10:06 pm
by Batfinnk
Glad to be of help hopefully. :biggrin3:
