http://home.comcast.net/~mtaylor68/rnseinstall.htm
Slightly less rare than rocking horse <beep> and hens teeth.
RNS-E Installation into a B5 RS4
- PetrolDave
You need a 4B0 035 192 P - that's a European model RNS-E for a C5 A6, which is the closest fit for a B5 A4/S4/RS4.g60bv wrote:which head unit is the one to go for. they all seem to have slightly different numbers and seeing as there close to 500 quid, i cant afford to get the wrong one.!
Try looking here for part number info:
http://www.navplus.us/forum/viewtopic.php?t=2
Is that the same for the facelift ?TDiAvant wrote:No, trying to complete a dash transplant would be a massive job, and I don't think it would fit.
To retrofit fit RNS-E into your car, would require the following parts
Double Din Centre console
Double Din Cage
Double Din Air Con unit (I think you could get one form ebay)
Double Din gearstick surround
Double Din ashtray (Not required if you don't smoke)
Audi Navigation Unit (A6 Version)
Wiring harness with can-bus
GPS Antenna
Switches (hazard waring etc)
It's not a massive job and an be easily complete 4-5 hours
Re: RNS-E Installation into a B5 RS4
Hi,
I have some problems with my rs4 b5 / RNS-E setup,
i would like to get the DIS to work, does anyone know what pins i need to connect my canbus H/L from rns to kombi? is it grey connector pin 5 and 6?
regards
jesper.
regards
jesper.
Using Tapatalk
Users browsing this forum: No registered users and 108 guests
