MMI Plus and SD cards - USB sticks, what am I missing?
PieterZ
Post by PieterZ » Thu Jul 05, 2018 11:04 pm
As said, I have an MMI Plus in my B9 RS4.
I tried to load my music from iTunes into a 64G USB stick first.
It is playable, but not all music is shown in the index when I open it.
So I changed to a 128G SD card.
And that does exactly the same.
I can see and play the same records and starting from the same record it can't be seen.
It only imports or shows a certain amount of albums, and I can't get it to go on any further.
Any input on what I'm doing wrong is very welcome.
Is the amount of music I can put on a memory device limited to a certain volume of data?
I can't seem to find anything in the manual.
If I stream from my iPhone (bt) or with Apple CarPlay it all works, so it can handle the format.
Do I perhaps need to let it sit for a few hours with the ignition on?
All black B9 RS4
cw08578
Re: MMI Plus and SD cards - USB sticks, what am I missing?
Post by cw08578 » Sun Jul 08, 2018 10:23 am
Depends on which format the music is as my mmi3g will only play mp4
Sent from my SM-G965F using Tapatalk
PieterZ
Post by PieterZ » Sun Jul 08, 2018 8:59 pm
I just checked.
Some are in .m4a and some in .mp3
.m4a plays without any hiccups, not sure about .mp3.
However, the issue is that not all albums are showing.
So even .m4a titles that are alphabetically later just don't show in the playlist.
Is the sd card reading ability limited to 2gb or so?
I'm puzzled.
All black B9 RS4
PieterZ
Post by PieterZ » Wed Jul 11, 2018 1:07 pm
Any help is welcome!
All black B9 RS4
PieterZ
Post by PieterZ » Fri Jul 27, 2018 11:03 pm
I still didn't solve it, nobody who has the same issues?
All black B9 RS4
Post by MikeFish » Sat Jul 28, 2018 10:02 am
I didn't have a B9 so can't speak from direct experience but from other Audis there are always restrictions on how many files the MMI can see. How many do you have in the card including folders and hidden jpgs etc? And there is normally a limit on how many folders levels it can go down to. Is this your issue?
The older units also had a restriction on maximum filename length, it think it was something like 28 characters and any file with a longer name than this would not be seen.
is it certain songs you can't see or entire folders? From my experience if you have too many files on one card you can normally see the folder but it appears empty.
RS6 Performance Panther Black KW Adjustable springs, Milltek Non-Res, exhaust valves disconnected & valve delete units fitted, TSW Bathurst, Eventuri intake
RS6 build thread: http://forum.rs246.com/viewtopic.php?f=76&t=119147
PieterZ
Post by PieterZ » Sun Jul 29, 2018 10:13 am
I have about 60gb of music on the sd card (first tried a usb stick).
I guess that is the case because on both the same amount of albums is visible and playable.
The rest of the albums just don't show in the playlist folder.
I guess it's about 2gb that shows and plays.
It is ordened alphabetically only artists starting with a and b are listed.
Now I stream from my iPhone by bt or apple carplay.
All black B9 RS4
Post by MikeFish » Sun Jul 29, 2018 11:45 am
Check how many files you have on the disc.
PieterZ
Post by PieterZ » Sun Jul 29, 2018 10:09 pm
I checked. There's 49gb.
I don't know exactly, but I think there are about 6000 tracks from copied albums.
All black B9 RS4
Post by MikeFish » Sun Jul 29, 2018 11:01 pm
The file size 49gb means nothing. Need to know how many files. But 6000 should be OK (don't forget to count folder, jpgs etc.
I think you can have something like 10,000 files max (including folders, jpg etc not just songs) and no more than 1000 files in any folder.
Have a look in the manual, I'd be amazed if this wasn't all explained in there.
PieterZ
Post by PieterZ » Mon Jul 30, 2018 12:06 am
Ok thanks! So far I found nothing in the manual.
Everything is in one folder called music, that will be the issue I presume.
I'll try to make more and see if this solves it.
All black B9 RS4
PieterZ
Post by PieterZ » Wed Aug 01, 2018 10:26 pm
A little update.
I made alphabetical folders on the sd card. A, B, C, ...
I then copied each artist in the propper alphabetical folder.
So far so good, but I haven't copied it all so far.
But what's on it works!
All black B9 RS4
PieterZ
Post by PieterZ » Wed Aug 01, 2018 11:08 pm
Everything is copied an it works!
A big thank you MikeFish. 👍
All black B9 RS4
Return to “Electrical”
Users browsing this forum: No registered users and 3 guests
