Audi Sat Nav + Aftermarket DVD CHANGER INSTALL HELP!
Mos_S3
Post by Mos_S3 » Sat Nov 26, 2005 7:12 pm
Hi guys how you doing? Im new to the forum, so just seeing how it goes....
Just a little bit of advice needed...
Fitted a SAT NAV + aftermarket installation into my audi s3 2002
Didnt, have the tmc tuner box, or the tv tuner.....
PROBLEM 1: Get this warning when ever I switch on the unit...."the tmc connection to rds-tmc tuner is faulty or could not be established"....have been told, I can program the unit not to look for the tmc, if this can be done, how could I do it? instead of just fitting the tmc.
PROBLEM 2:
Brought a 6 disc dvd changer, and a multimedia adapter made for audis to view on Sat Nav +
Just wanted to ask, what button to I select to actually "SEE" the input....???
I have wired all the stuff up....but not actually even sure, if a 6 Disc DVD changer will be compatable, but then I thought about it
and thought that its not directly hooked up to the sat nav +, its signal goes into the adapter first, then through there into the unit..
PROBLEM 3:
This is the unit I brought, thought everything would be fairly easy, but having trouble with the signal, not sure if its getting there..
http://cgi.ebay.de/MULTIMEDIA-ADAPTER-2 ... dZViewItem
Any help is appreciated GUYS
Thanks.
Dippy
RE: Audi Sat Nav + Aftermarket DVD CHANGER INSTALL HELP!
Post by Dippy » Mon Nov 28, 2005 2:16 pm
1) You SatNav+ came from a system which had TMC, so it will always look for it. You can reprogram it with VAG-COM.
2-3) That unit looks like it is using the SatNav+ TV input, so to get it working you need to use the Radio/CD/TV button to select TV. Of course this means you'll need to have the TV function programmed - VAG-COM again.
2001 Silver S4 Avant
Mos_S3
Post by Mos_S3 » Tue Nov 29, 2005 1:37 pm
Thanks alot dippy....
My next question would be if there is anyone in the north east london area (CHINGFORD/STRATFORD) with a VAG.COM computer, who is willing to meet me? or come see me?
Obviously I will pay them for their services...
much appreciated guys!
If you pm me, or just contact me via email
mo_786@hotmail.com
Thanks....
Return to “Electrical”
Users browsing this forum: No registered users and 40 guests
