B7 S4 Power Seat Fuse?
teletubby
Post by teletubby » Mon Jun 24, 2013 7:09 pm
Hi,
The driver's seat has stopped working and nobody (even main dealer!!) seems to know where the fuse is?
It's not in the normal fuse panel is as much as I know, anybody here got any ideas please?
Thanks in advance.
Batfinnk
Re: B7 S4 Powers Seat Fuse?
Post by Batfinnk » Mon Jun 24, 2013 7:15 pm
Have you looked in the owners manual?
Plus if I'm right there are two fuse boards?
Previous car: 2005 S4 B7.
teletubby
Post by teletubby » Mon Jun 24, 2013 7:18 pm
Yes, had a look, no help at all.
Where might the second fuse board be?
Batfinnk
Post by Batfinnk » Mon Jun 24, 2013 7:21 pm
I think it is either under the bonnet or behind the glovebox. I just looked through my manual and the closest fuse I could see would be number 38. Your right though, none listed for the seat power specifically. Have you had a look and checked the seat plugs are still connected?
teletubby
Post by teletubby » Mon Jun 24, 2013 7:32 pm
As far as I can feel it's still connected. Is there more than one connector?
Batfinnk
Post by Batfinnk » Mon Jun 24, 2013 7:37 pm
I think there are quite a few plugs under each seat plus under the carpet under the passenger seat there are some modules too!
teletubby
Re: B7 S4 Power Seat Fuse?
Post by teletubby » Mon Jun 24, 2013 7:39 pm
Aah, thanks, I'll go and have another look.
teletubby
Post by teletubby » Mon Jun 24, 2013 8:53 pm
Can't see (or feel) any loose wires or find any other fuses.
Looks like it's off to let the local specialist take a look. :(
Batfinnk
Post by Batfinnk » Mon Jun 24, 2013 9:36 pm
Check fuses 44 and 45. Does the passenger seat still work and do you have heated seats?
Batfinnk
Post by Batfinnk » Mon Jun 24, 2013 9:42 pm
Just did some searching and found out there are some fuses and relays hidden behind the lower dash trim on the drivers side and there are fuses there for the seats.
teletubby
Post by teletubby » Mon Jun 24, 2013 9:54 pm
Checked and both fine.
Yes, passenger seat works fine and no, I don't have heated seats.
Any idea how the lower dash trim come out / I can get access?
Thanks very much!
Batfinnk
Post by Batfinnk » Mon Jun 24, 2013 10:00 pm
Not too sure how the dash panel comes off tbh. Try using the search on here. It is very useful at times :thumbs:
teletubby
Post by teletubby » Mon Jun 24, 2013 10:03 pm
cool, thanks.
Batfinnk
Post by Batfinnk » Mon Jun 24, 2013 10:06 pm
Glad to be of help hopefully. :biggrin3:
Return to “Electrical”
