What turns on the radio????
As the title says what turns on the radio (RNS-E). I have a problem at the minute with the radio. Here goes put the key in and start the car everything is fine. Stop the car but leave the key in the ignition and the radio turns off and on so does the Bluetooth module. Someone suggested that the 86s contact on the ignition switch might be faulty. Check it with a multi meter and it's fine so where do I go now?? Any help would be great.
- PetrolDave
RE: What turns on the radio????
The RNS-E turns on/off in response to messages on the Infotainment CAN bus, so it's nothing at all to do with the ignition switch or the 86s contact.
Re: RE: What turns on the radio????
Hi Dave, Thanks for that it had crossed my about the can bus system but an audi tech told me to check the 86s contact, should have known betterPetrolDave wrote:The RNS-E turns on/off in response to messages on the Infotainment CAN bus, so it's nothing at all to do with the ignition switch or the 86s contact.
Bluebrakes
RE: Re: RE: What turns on the radio????
pretty important.
It stops interference by one being an inverted signal of the other wire.
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
