ADVICE NEEDED
ADVICE NEEDED
my Audi RS6 has the engine management light on, the ESP light on, after the DRC was replaced any advice what it can be thank you
- PetrolDave
RE: ADVICE NEEDED
You'll need to use VAG-COM to check what fault codes the engine ECU has logged, there are literally hundreds of reasons for the check engine light to be on.
The ESP light is probably on because the battery was disconnected, when you need to recalibrate the steering wheel sensor - the details are on the Ross-Tech website.
