Coolant Temperature Gauge
This is a general question about the temperature gauges in Audis. But currently very relevant to my '51 A4 1.8T.
The A4 is losing about half a litre of water a day. I think it's a leak rather than cylinder head gasket. It's going to a garage today!!!
My query: After starting the car (after topping up coolant), the gauge needle goes up to the usual 90 degrees and stays there. After 20 mins or so, the Coolant Temp warning symbol flashes and beeps but the gauge remains at 90. A few minutes later the warning flashes again. But still the gauge remains at 90. In fact, it never drops or rises ever!!!! Is this normal? Surely if the coolant temp symbol appears, it is advising that the temp is too high - so why doesnt the needle rise????
- PetrolDave
RE: Coolant Temperature Gauge
Coolant temperature gauges on Audis are setup to show 90 degrees whenever the coolant temperature is in "the normal range" - to stop owners asking why there car runs hot or cold (according to the gauge). Means the coolant temperature gauge is only able to show you that the coolant is cold, or really, really hot!
Ok. so, even though the coolant temperature warning symbol comes, the actual coolant temperature is still within 'normal' range??? presumably if the gauge ever went higher than 90 it would be seriously hot and basically in the 'danger' range?
- PetrolDave
Re: RE: Coolant Temperature Gauge
You got it!jd_hants wrote:presumably if the gauge ever went higher than 90 it would be seriously hot and basically in the 'danger' range?
RE: Re: RE: Coolant Temperature Gauge
Thats useful then!!!! Is there any way to use VAGCOM to display the actual temperature rather than the 'heavily filtered' one???
Have you any idea at what temperature the coolant temp warning symbol comes on??? Presumably I'm still ok to drive. Just keep an eye on the gauge in case it leaps to the right, which I also assume can happen pretty rapidly?
Both at or at least almost, the same time. I'm a bit of an anorack when it comes to these things (aren't we all!) and was watching the guage as we asscended the pass. It's quite a road though so would have been watching outside the car mostly of course, but it all happened very quickly! As you commented further up this thread, very useful!
MartynC
MartynC
Users browsing this forum: No registered users and 60 guests
