Lidatek LE-30
dhali
Post by dhali » Tue Feb 20, 2007 12:11 am
[quote="Tartan_Rob"]
It is also one of only a few devices that still shows a zero speed when the laser gun is used in stealth mode and it does not trigger an error code (which the Police log) but it ensures that speed is recorded as zero mph.
now i really like the sound of that :D
Jarv
Post by Jarv » Tue Feb 20, 2007 12:14 pm
Top thread.
Couple of questions.
UKS4APR1, nice stealthy install. Have you got any more shots you can post, particularly from above? Did you modify the grille to fit it?
I'm undecided between a Target LRC100 and a Lidatek LE30. I have an Origin B2 Solo with the optional radar detector (located behind bottom centre grille), and I know that your can use the B2 Solo as an interface with either of those two devices, though as I have the Solo version I would need to ditch the standard fit laser detector. Has anyone done this, if so, how did they get on. Would they say it was better to forget connecting it up to the Origin and just go for the separate install?
Mike
Q7
tartan_rob
Post by tartan_rob » Tue Feb 20, 2007 2:35 pm
Fitting was okay. But I wanted it quite stealthy and low (so as not to detect car in front), I only have the front as I already have rear PDC. See pictures below
2017 Kawasaki Z1000
2014 RS6
2014 S1
Return to “Electrical”
