I have a 2004 S4 with a Symphony II head unit and Bose.
The speed sensitive volume doesn't appear to be working, my previous car was a '97 2.8 Avant where it worked perfectly.
Not sure whether I have GALA or the Bose Audiopilot but I've read that it is possible to disable the volume control and I can only assume that it is currently disabled.
Does anyone know how I switch it on/off from the Symphony II head unit?
GALA/Audiopilot control
- PetrolDave
RE: GALA/Audiopilot control
If you have a GALA or DSP entry in the menu - then GALA is enabled.
You may need to check the coding of the Symphony II using e.g. VAG-COM.
My 2003 S4 had the old version of Bose which had GALA, but my 2004 S4 has Bose with AudioPilot - not sure when the changeover happened.
To access GALA setting, turn off the stereo, then turn back on holding TP in. Then scroll through and adjust as needed. GALA at 5 is max.
APR 270bhp S3, Mixer K6 750
Cheap performance tip - lie the rear seats flat
