Hi
I know its been covered before and I looked back at other threads but any references to links and files are not working anymore.
Does anybody have detailed information on how to get TV on the move on Navplus in an RS6?
Andy
TV on the move
RE: TV on the move
If its the same as the RS4 Nav+, then all you need to do is disconnect the GALA wire (white/blue on mine) from the rear of the head unit.
Apparently you may lose some accuracy on your GPS position, as the Nav unit uses the GALA signal in conjunction with the satellites to give a more accurate position, and also (not sure) but I think you also lose the speed dependant volume control.
I have run a very simple "loop" into the glovebox in my car so I can connect and disconnect whenever I want to. I know others have fited a discreet swith under the dashboard as an alternative.
Hope that helps,
Paul.
Hope that helps,
Paul.
Golf R - with added MRC
Sprint blue B7 RS4 Avant - Sold
Ultimate Silver Nissan GT-R - Sold
Avus MRC 470 B5 RS4 Avant - Sold
Andy, for RS6 I know that others (without electric blinds installed) have used this blank button space to put in a switch for tv in motion.
Present:...
Past:
Past:
