Driveline Shunt
Posted: Mon May 26, 2003 12:10 pm
by Greg_S
Ive been reading through the S4 posting about the driveline stabaliser on the snub mount for the S4.
what determines the design for this so that one could be made suitable for the S2 which also suffers with the same problem?
Havent managed to find a manufacturer of them for S2 either.
Re: Driveline Shunt
Posted: Wed Jun 04, 2003 10:27 am
by Greg_S
had a word with powerflex and they are interested in makine one for the S2 just need to provide them with some pictures etc. Need to know how many of you are interested in making the gear change a bit more slick?
Greg
Re: Driveline Shunt
Posted: Wed Jun 04, 2003 12:24 pm
by Doug_RS2
I'm interested.
Re: Driveline Shunt
Posted: Wed Jun 04, 2003 1:32 pm
by foomans2
Hi Greg,
I'd be interested in a new front mount. I'll try and catch up with All Audi on Friday and see if I can get an old one off one of their coupes. If I can, do you want me to send it to you?
I've found that jacking up the rear gearbox mount and moving the front snub mount bracket down, so it's hard up against the rubber helps to reduce the front to back movement. This definately helps to reduce the variation in gearchange smoothness. Also take a look at the gearstick knuckle joint. If the rubber has come away from the metal plate, this will add to the problem. A new plate and rubber bush is about £35.
HTH
Steve. [img]images/graemlins/24430-audibash.gif[/img]
Re: Driveline Shunt
Posted: Wed Jun 04, 2003 6:56 pm
by markhalligan
Greg,
Me too.
Mark.
Re: Driveline Shunt
Posted: Thu Jun 05, 2003 2:31 pm
by Greg_S
Thats excellent if you can get hold of one from all audi, do you have the audi part no's for it also? contact me off the board and we can get something sorted out. [img]images/graemlins/biggrin3.gif[/img]
