New 6 pot brakes fitted....
Posted: Mon May 05, 2003 7:36 pm
I have had my 6 pots on for a few weeks now. Whilst cleaning the wheels today I thought it was about time I posted an image on the forum. This is the best I can do until I replace my digital camera with something better to post in the gallery.
Note: clean wheels, dirty car, crap camera!!!
System consists of:
AP CP5555 6 pot calipers
360 mm Audi RS4 OEM disks
Custom caliper brackets: Aluminium 6082-T6, hard anodised (designed by myself, manufactured by an aerospace company)
Braided lines
EBC Greenstuff pads
Braking performance is now phenominal! Whilst the standard brakes were wholly inadequate I can now quite easily slow the car with the ABS working flat out from 80 mph. I haven't really given them a thrash yet to determine their fade resistance.
By using the standard RS4 disk it gives me the option to go for GMBH disks or even designing an interchangeable 362 mm AP disk on a fully floating bell if I think I need better performance. I will decide when it is time to change the disks but already it seems that the gasses built up under the very large pad would benefit from an escape route either through drilled or grooved disks. I am not a fan of drilled disks on a non-floating bell as I have seen too many of them crack on other cars due to the thermal stresses.
Clearance is very tight in the 18" OZ wheel and I even had to polish the tops off the balancing masses to make some room! I only took off less than 5% of the counterbalance mass so the wheel balance is still good and they remain smooth even at 150.
When it comes to changing the tyres I will free-issue lower profile masses (stamped with their corrected weight) to the tyre fitters.
Lee
System consists of:
Braided lines
EBC Greenstuff pads
Lee
