s2 upgrades
s2 upgrades
hey there people need some help tuning my s2 any one got any advice?[/b]
RE: s2 upgrades
Welcome!
Yea, there's loads you can do. What did you have in mind?
You could start with a Miltek catback exhaust, RS2 downpipe, and MRC remap. That will give you close to 300bhp.
If you want to go a bit further, then a bigger turbo and intercooler, exhaust manifold, reverse intake manifold, bigger injectors and fuel pump will give you 400bhp+
Handling-wise, RS2 or Whiteline ARBs are a good starting point. H&R coilovers or similar would be the next step.
Lastly, but probably firstly, do the Porsche 996 front brake upgrade - the stock brakes are $hite.
That's a brief summary, but there's a wealth of information and advice here : www.s2forum.com - come and join us
Clive
RE: s2 upgrades
hey clive thanx for the advice! ok i forgot to mention i have a full streight through stainless vortex system which i had built so i definatly wanna go for the braking and handling at the mo. so 996`s on the front huh? what about the rear?
RE: s2 upgrades
anyone know if its possible to put the rs2 clutch in the s2?im tryin yo get the handlin and brakin sorted at the mo tho anyone with any info please please gimme a shout. cheers. s2z
Re: RE: s2 upgrades
Front is the most important, but if you want to go the whole hog, there are various options - take a look at this one : http://www.s2forum.com/forum/showthread.php?t=13798s2z wrote:hey clive thanx for the advice! ok i forgot to mention i have a full streight through stainless vortex system which i had built so i definatly wanna go for the braking and handling at the mo. so 996`s on the front huh? what about the rear?
Clive
Re: RE: s2 upgrades
Yes, but why do you need to do that? Are you planning on a big turbo upgrade generating loads more torque? There are also other options.s2z wrote:anyone know if its possible to put the rs2 clutch in the s2?im tryin yo get the handlin and brakin sorted at the mo tho anyone with any info please please gimme a shout. cheers. s2z
Handling - start with replacing the ARBs with RS2 front and Whiteline rear.s2z wrote:im tryin yo get the handlin and brakin sorted at the mo tho anyone with any info please please gimme a shout. cheers. s2z
If you're not happy with that, it's coilover time...
Brakes - as above.
Clive
Re: RE: s2 upgrades
yeah thanks mate ive decided to go for the kw coilover setup and the porsche brakes on front and s4 on rear.for the engine i wanted to know whats the max bhp i can run on standard internals not that they are gonna stay standerd but can i fit a bigger tubo then do the internals?CliveH wrote:Yes, but why do you need to do that? Are you planning on a big turbo upgrade generating loads more torque? There are also other options.s2z wrote:anyone know if its possible to put the rs2 clutch in the s2?im tryin yo get the handlin and brakin sorted at the mo tho anyone with any info please please gimme a shout. cheers. s2z
If you're not happy with that, it's coilover time...![]()
Brakes - as above.
Re: RE: s2 upgrades
Brakes - as above.[/quote]
[/quote]
what are ARBs?
what are ARBs?
RE: Re: RE: s2 upgrades
ARB = Anti roll bar
Clive
Firstly, Is your car an ABY or 3B? (6 or 5 speed)
Stock internals will take upto around 400bhp on ABY engine, about 370-380 on 3B. Headgasket needs replacing with metal RS2 item if you are going above 350ish.
Users browsing this forum: No registered users and 20 guests
