Milltek Problem
Posted: Thu Dec 31, 2020 1:47 pm
Hi all - had a Milltek fitted in the summer to my C8 and developed a problem in the last couple of days.
Basically the valve on the passenger side of the exhaust currently has a mind of its own, opening and closing randomly even when on idle, while the driver side one only opens and closes as it supposed to as per the exhaust setting. Its constantly doing it, occasionally staying shut for a few seconds then opening again, then immediately shutting again, then opening again (you get my drift)
Means that as I drive along I have the exhaust sounding loud / quite / loud / quite ever few seconds etc for any journey. Which is bloody annoying!
Seemed to first happen after about 45mins motorway run. I have used some WD40 to see if that worked and the value was clogged up but to no avail. Probably going to have to go back to where I had it fitted (as it will still be under warranty) unless its a quick fix and someone else has experienced it before?
