How to use the full range of adjustable suspension
Posted: Wed Dec 09, 2020 3:48 am
by nordmenn
Is there anyway to use the full range of adjustable suspensions? The factory settings for lowering does not go all the way down it seems, on the display in the car there seems to be 3 more levels to go but have not found a setting that enables the last 3 levels (still 3 bars on the graphic) to move down.
Is there a way to lower the car all the way down?
thanks!
Posted: Wed Dec 09, 2020 11:39 am
by mattwez378
It will go to the lowest bar when in RS mode with the suspension set to dynamic
If you have changed no settings RS2 will do it but RS1 won’t, you can modify RS1 to do it though
Re: How to use the full range of adjustable suspension
Posted: Mon Dec 14, 2020 6:09 pm
by dannyuk
Yeah the bar thing is a bit weird, as far as I know, you can't fine-tune it, its either up, down or middle!
Posted: Thu Dec 17, 2020 7:44 pm
by Jezzer
Is this on air suspension cars?
Posted: Thu Dec 17, 2020 7:46 pm
by mattwez378
Jezzer, mine is on air. I believe the DRC suspension doesn’t have the ride height indicator but I may be wrong about that
Posted: Thu Dec 17, 2020 7:55 pm
by Jezzer
mattwez378 wrote: ↑Thu Dec 17, 2020 7:46 pm
No indicator in mine
