TPMS malfunctions on RS6 C8
Posted: Wed Sep 30, 2020 8:09 am
by Jezzer
Warning came up on dash last night so checked tyres and tyre pressure Display on MMI. Tyres okay but the reading for drivers front tyre not showing where rest of the tyres readings all there. Reset the tyre pressure settingS and after ten minute drive warning disappeared but only to reappear with another warning twenty minutes later. Tried again same thing happened again. Anyone else experience this before and how was it resolved?
Re: TPMS malfunctions on RS6 C8
Posted: Wed Sep 30, 2020 5:39 pm
by MikeFish
Try swapping wheels around to see if the fault moves to the other side or if it stays in the same place. That should tell you if it is the sensor or the aerial that has the issue. Either way. get the dealer to sort it out.
Posted: Wed Sep 30, 2020 7:37 pm
by Jezzer
Thanks Mike, good idea! Any idea on torque settings for wheel bolts?
Posted: Wed Sep 30, 2020 7:58 pm
by MikeFish
Pretty sure all Audis are 120NM.
Posted: Thu Oct 01, 2020 11:17 am
by Tadass910
Yea it’s a pain in the ass one sensor cost me with labor at Audi dealer about nearly 500 eur
Posted: Thu Oct 01, 2020 9:27 pm
by mgoliveruk
this would be covered under the warranty, wouldn’t be?
Posted: Thu Oct 01, 2020 10:25 pm
by Jezzer
Yes especially as I’ve only done 400 miles
Posted: Fri Oct 02, 2020 2:42 pm
by Fish4683@yahoo.com
Nope, I had a nice Warning that my headlights have failed and need to contact the workshop. All seemed ok as I scrolled through headlights,sidelights and Auto??? I’ve only done 1000 miles.
Posted: Sat Oct 03, 2020 10:21 am
by Jezzer
Did the headlight warning disappear after a while?
Posted: Sat Oct 03, 2020 4:00 pm
It stayed on until I turned ignition off. When I turned ignition back on there has been no warnings, fingers crossed
Posted: Sat Oct 10, 2020 12:35 pm
by Michael_JCWS
Just call Audi emergency and ask for an Audi technician to come out
Posted: Tue Oct 13, 2020 9:31 pm
by Tadass910
Op did you managed to solve an issue?
Posted: Tue Oct 13, 2020 9:51 pm
by wossel
Hey Jezzer, i have the same fault, did you figure out what the issue was? thanks in advance
Posted: Wed Oct 14, 2020 7:21 am
by Jezzer
Yes I had it repaired yesterday. It was the TPMS control unit not the valves in the tyres at all. The tyre pressures and temperature readings showing on the MMI were going on and off on all four corners all the time so I knew then that it couldn’t have four faulty valves. Luckily they had a brand new car that they could take one off as they said it could have been a two week wait for a new one.
