TPMS malfunctions on RS6 C8
Warning came up on dash last night so checked tyres and tyre pressure Display on MMI. Tyres okay but the reading for drivers front tyre not showing where rest of the tyres readings all there. Reset the tyre pressure settingS and after ten minute drive warning disappeared but only to reappear with another warning twenty minutes later. Tried again same thing happened again. Anyone else experience this before and how was it resolved?
Misano Red RS4 B8 450 PS
Phantom Black RS4 B7 444 BHP
Re: TPMS malfunctions on RS6 C8
Try swapping wheels around to see if the fault moves to the other side or if it stays in the same place. That should tell you if it is the sensor or the aerial that has the issue. Either way. get the dealer to sort it out.
Thanks Mike, good idea! Any idea on torque settings for wheel bolts?
Pretty sure all Audis are 120NM.
Yea it’s a pain in the ass one sensor cost me with labor at Audi dealer about nearly 500 eur
- mgoliveruk
this would be covered under the warranty, wouldn’t be?
Mgoliveruk
1999 A4
2001 S3
2004 A4 Cabriolet Silver
2007 A5 3.0 TDI Ibis White
FL 2012 S4 Avant Ibis White, with panda supersports seats
2017 S4 Avant Navarra Blue
2020 RS6 Vorsprung Tango Red
1999 A4
2001 S3
Yes especially as I’ve only done 400 miles
Fish4683@yahoo.com
Nope, I had a nice Warning that my headlights have failed and need to contact the workshop. All seemed ok as I scrolled through headlights,sidelights and Auto??? I’ve only done 1000 miles.
Did the headlight warning disappear after a while?
Fish4683@yahoo.com
It stayed on until I turned ignition off. When I turned ignition back on there has been no warnings, fingers crossed
Michael_JCWS
Just call Audi emergency and ask for an Audi technician to come out
Current:
2023 RS6 C8 Performance carbon black Vorsprung- Daytona grey
Most recent
2020 RS6 C8 Vorsprung- Nardo grey
2017 RS6 C7 Performance - Daytona grey
2014 BMW M5 F10 - Monte Carlo blue
Most recent
Op did you managed to solve an issue?
Hey Jezzer, i have the same fault, did you figure out what the issue was? thanks in advance
Yes I had it repaired yesterday. It was the TPMS control unit not the valves in the tyres at all. The tyre pressures and temperature readings showing on the MMI were going on and off on all four corners all the time so I knew then that it couldn’t have four faulty valves. Luckily they had a brand new car that they could take one off as they said it could have been a two week wait for a new one.
