After 11 days of ownership, I think if one thing is going to annoy me, it is the start stop system.
Of course I turn it off, but it doesn't remember that I turned it off and keeps turning it back on again.
I hoping there is a way to make the car remember the setting or get it to default to off.
Has anyone found a way to fix this?
Start Stop Coding? (Hopefully)
Gone : 2017 M3 CP
Gone : 2007 B7 RS4 ( )
Gone : 2017 M3 CP
Re: Start Stop Coding? (Hopefully)
Used to be a voltage thing so VCDS needed to turn it off. That way though you can't turn it back on again without a laptop and cables. I don't like it either although sometimes (stop start traffic) it's OK.
TX.
TX.
there was a fix for the SQ5 i did it n my wife's one where it remembered the last setting
from MYAudiQ5.com it might be a similar coding
I can confirm the below vag mode works on my Q5 :
- module 09-Cent. Elec.
- enter Security Code (shown up by default) (mine i 20113)
- Adaptation, Type Channel 34 and hit Read button, it should show the factory default number.
subtract 4 to the value --> Start&Stop always disabled
add 32 to the value --> remember last status
- test & save
In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
My car original number is 28, and I changed it to 60. So if the last time, Start /Stop is disable (light is on), then when engine is switch on next time it is still disable (light is still on).
Or if you wanna get rid off that extra light on button, just put in your car number + 64 and save it.
Cannot happier.
- test & save
Cannot happier.
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Thanks for the info.Brooner wrote: ↑Wed Jun 13, 2018 12:55 pmthere was a fix for the SQ5 i did it n my wife's one where it remembered the last setting
- test & save
Cannot happier.
What hardware did you need to do this?
Gone : 2017 M3 CP
Gone : 2017 M3 CP
Vag Com cable and software the cable is about £200 and the software is a free download
Vagcom is called VCDS now.
I did exactly as Brooner described with by C7 i.e. made it remember the last setting and inverted the LED light so it is only on when start / stop is on meaning the light is always off in my case.
My wife's RS3 didn't have this option though so I did as TX mentioned and raised the minimum working voltage to make sure it never comes on (if the car thinks the battery is too flat it will deactivate the start / stop function
TX Brooner MikeFish thanks for the info guys.
Remembering the last setting and inverting the light would be ideal.
Did you use one of the "Ross Tech" cables?
Is this the right product?
https://store.ross-tech.com/shop/vchv2_ent/
I have scanned through Ross Techs wiki, it talks about B6 B7 and B8 but nothing later.
Gone : 2017 M3 CP
Gone : 2017 M3 CP
Users browsing this forum: No registered users and 72 guests
