Fitting a utr 2.0
Posted: Thu Jul 18, 2024 10:57 pm
by snewton
Just been quoted £768 by audi preston to fit my front and rear dash cams, to rs4 b9, 4 hours labour only
Certainly won't be taking it there, has anyone got a diagram of what I need to do to fit myself, I have the loom so just need some pointers as to what to look for, thanks in advance
Re: Fitting a utr 2.0
Posted: Fri Jul 19, 2024 8:53 am
by Jools
Does the pdf attached in reply to your last post on this not give you enough detail?
Posted: Fri Jul 19, 2024 5:53 pm
by snewton
Thanks Jools I looked straight through that, my apologies, and sorry for not thanking you,
I should have said my car is an rs4 avant
I have looked through the pdf, so I would follow the A4 install instructions?
Many thanks
Posted: Fri Jul 19, 2024 10:10 pm
by Jools
To be honest I don't know hand on heart if the RS4 installation differs from A4 installation.
I would think not, as in my search I couldn't find a specific RS4 avant installation document.
Additionally the RS4 is an A4, just a wolf in sheeps clothing.
I would start by removing the fuse panel covers and see if the required tapping points are the same and available.
Your loom cable lengths will dictate if the shown runs are viable.
Best of luck.
Posted: Tue Jul 30, 2024 5:40 pm
by snewton
So was a little complicated, so took to local fitter, however the loom that I was told was correct AUDI WIRING HARNESS FOR DASH CAM (traffic recorder 1.0 and 2.0) 4G0063511AA
Now fitter has told me that it isn't long enough, but should be able to splice, can anyone confirm if this is correct
The green 15 wire is ignition
The red 30 wire is constant live
Black is ground.
Many thanks in advance
Posted: Fri Aug 09, 2024 9:08 pm
by Jools
Having a quick look your wire colours and attachment points look right.
The constant live looks like the garage door opener supply on my wiring diagrams, if fitted.
I hope this helps
