Faulty Temperature Sensor
Posted: Tue Nov 28, 2023 2:47 pm
Hi all, new here, but I've had my 2018 RS4 B9 for 3 years now.
For the last 2 years, it has had an intermittent fault with the cooling system. Suddenly, without warning, the water temp gauge reads wrong (usually way too low) and the fans come on full blast.
After turning car off, they continue for a few minutes.
When starting cold, the fans come on full blast immediately.
The oil temperature is always fine, correct. There doesn't seem to be any overheating issue at all.
Sometimes the fault will suddenly disappear by itself, and everything goes back to normal.
Otherwise, I have to clear the fault with an OBD reader.
So I think I need to change a temperature sensor - one OBD said it was an unreliable cylinder head sensor. Does anyone know where this is or how easy it is to get to?
Many thanks in advance!
