Page 1 of 2
Wheel Spacer's
Posted: Tue Jan 18, 2022 12:27 pm
by wellzieRS4
Has anyone fitted wheels spacers to their car, if so what sizes have you fitted, I've see a few posts people going wider on the back, like 20mm back,15mm front or 15mm back, 10mm front.
Im not sure on staggering them, id would of thought keeping sizes same front and back would be better but I'm not sure
Any opinions or pictures would be great
Im going to be fitting MSS adjustable springs too
Re: Wheel Spacer's
Posted: Tue Jan 18, 2022 8:15 pm
by wellzieRS4
On another subject i got Google Earth back on today, only cost £25 .......... Which was nice
Re: Wheel Spacer's
Posted: Wed Jan 19, 2022 7:20 am
by Brooner
im sure some one here did spacers on the standard wheels but i cant find the thread
an easy way would be place a peace of wood against the wheel up to the arch and mark he distance measure it then that would be the max spacer keeping the tyre inside the arch
Re: Wheel Spacer's
Posted: Wed Jan 19, 2022 7:57 am
by rjwojcik
Brooner wrote: ↑Wed Jan 19, 2022 7:20 am
Exactly what I do as well
Re: Wheel Spacer's
Posted: Wed Jan 19, 2022 9:18 am
by wellzieRS4
Good idea
Re: Wheel Spacer's
Posted: Thu Jan 20, 2022 7:42 am
by Markp
I run 19s with 10mm all round. Perfect for me, and doesn’t look like I am trying too hard.
Re: Wheel Spacer's
Posted: Thu Jan 20, 2022 7:43 am
by Markp
wellzieRS4 wrote: ↑Tue Jan 18, 2022 8:15 pm
How?
Re: Wheel Spacer's
Posted: Thu Jan 20, 2022 9:57 am
by wellzieRS4
Markp wrote: ↑Thu Jan 20, 2022 7:42 am
What spacers have you fitted and where did you get them
I’m struggling to find any that fit B9 RS4
Do you know what the centre bore size is
Re: Wheel Spacer's
Posted: Thu Jan 20, 2022 10:00 am
by wellzieRS4
Markp wrote: ↑Thu Jan 20, 2022 7:43 am
How?
From a company called MAk Coding, they sent me the files and I put them on a SD card and updated it, it was easy I also got speed camera alerts file off them for £30
Works a treat but you need to have a active Audi connect subscription
Re: Wheel Spacer's
Posted: Thu Jan 20, 2022 3:55 pm
by rjwojcik
wellzieRS4 wrote: ↑Thu Jan 20, 2022 10:00 am
How?
This one?
https://www.makcoding.co.uk/
Re: Wheel Spacer's
Posted: Thu Jan 20, 2022 10:19 pm
by wellzieRS4
rjwojcik wrote: ↑Thu Jan 20, 2022 3:55 pm
How?
This one?
Yeah that's it
Re: Wheel Spacer's
Posted: Sun Jan 23, 2022 6:54 pm
by Markp
wellzieRS4 wrote: ↑Thu Jan 20, 2022 9:57 am
Don't know bore size. I used Bimmec (TUV approved) - this sort of thing:
https://www.ebay.co.uk/itm/333371543119 ... %3A2047675
Re: Wheel Spacer's
Posted: Sun Jan 23, 2022 7:43 pm
by rjwojcik
CM Wheels also supply Bimmec, but the ebay ad looks perfect to me. Or contact a supplier and tell them what you've got and what spacer you need.
From the notes I made when looking:
The wheels for the RS4(B9) use a PCD of 5x112, centre bore 66.5mm and M14x1.5 bolt.
Standard bolt is M14x1.5 R13 27mm thread, 17mm hex.
Don't forget to get a set of new locking wheel nuts as well?
What wheels have you got? If standard RS4 wheels, they all have different offsets, so would potentially require different spacers.
Re: Wheel Spacer's
Posted: Mon Jan 24, 2022 11:15 pm
by wellzieRS4
rjwojcik wrote: ↑Sun Jan 23, 2022 7:43 pm
Ive got carbon edition so its got 20in 5 spoke milled wheels, so the centre bore is 66.5mm but all the spacers i can find seem to be 66.6mm, would this be ok , when I've added my vehicle on eBay and some other sites they don't seem to come up with anything compatible or maybe I'm missing something
Re: Wheel Spacer's
Posted: Mon Jan 24, 2022 11:39 pm
by rjwojcik
ET22 then... I'm using 10mm spacers on mine and they're the 66.6 ones.
I sent an email to email CM Wheels, with the following:
Hi
I'd like to order a set of 4 10mm wheels spacers, with bolts, locking wheel bolts and 2 keys, all in black. The website only allows for one key.
To fit the following reg: ???????
Many thanks.
Kind regards
