Head Up Display Retrofit - A4 B9 8W
Posted: Mon Mar 08, 2021 12:41 am
by Pturner3
Hi,
Has anyone any experience with retrofitting Head Up Display KS1 to A4 B9? My car is 2019 Sport Edition RS4.
I have VCP, HEX-NET and current flow diagrams, workhop manual.
Looking into this the hardware side looks fairly straight forward:
Dash: 8W2857001J
HUD unit with integrated contorl module (J898): 8W5919617C
Light switch for HUD adjustment: 4M0941531P
New windscreen - lets place this requirement aside for now...
Looking at the current flow diagrams, there doesn't appear be too much wiring to connect. Would be interested to seek advice, and also on coding, using 2nd hand HUD, HUD calibration etc...
Thanks,
Phil
Re: Head Up Display Retrofit - A4 B9 8W
Posted: Tue Jun 29, 2021 5:58 am
by Pturner3
Done
Posted: Tue Jun 29, 2021 7:24 am
by rjwojcik
Wow, well done
Posted: Tue Jun 29, 2021 11:16 am
by RS Owner
I never realised that HUD equipped cars have a different windscreen. Learn something everyday :D
Posted: Thu Jul 01, 2021 2:39 pm
by elchet
Would you be up for sharing learnings, and any photos of the process if you have them?
Posted: Sat Jul 10, 2021 4:02 pm
by rjwojcik
Would you know if you can configure what is shown on the standard and sport HUD display?
Posted: Sun Jan 02, 2022 8:03 pm
by Pturner3
Apologies, I'm not here often as you can tell!
I have a full write-up guide if anyone wants it... Pm me.
Posted: Fri Jan 07, 2022 12:09 pm
by wellzieRS4
Pturner3 wrote: ↑
Have you retro fitted B & O
Posted: Fri Jan 07, 2022 12:29 pm
by Pturner3
Hi,
No I haven't, sorry. Best place to start is an official parts website to see what you need. And then get hold of the current flow diagrams to check connections. Is your car a UK vehicle?
It can be quite involved to research what is required for retrofits, as other components can be affected and may not be compatible without upgrade too.
Look up PR codes for the equipment you want to fit. Then use current flow diagrams to see all the modules and components the system connects to. Then go to parts manual and find out all the parts needed that are unique to the PR code of the equipment you want to fit. Lots of back and forth and tracing things out. Often it may not be economical unless you can get everything second hand. It's not always as simple as just buying the B&O parts for example... But I don't know. There are just quite a few considerations..
Posted: Fri Jan 07, 2022 12:40 pm
by wellzieRS4
Pturner3 wrote: ↑
Hi,
Cheers, it does look like its probably not worth the hassle tbh, i wouldn't have a clue about flow diagrams i paint cars for a living, i might look at upgrading the speakers aftermarket and fit B & O speaker covers maybe
The spec aint to bad on my car and had most things i wanted but had to compromise with B & O, do you know if road speed sign recognition is easy to do, i have head up display
Posted: Fri Jan 07, 2022 12:44 pm
by Pturner3
Are you from the UK?
TSR needs front camera, firmware update and coding.
Posted: Fri Jan 07, 2022 1:42 pm
by wellzieRS4
Pturner3 wrote: ↑
Yeah I’m in the uk, will my car have the camera
Posted: Fri Jan 07, 2022 2:33 pm
by Pturner3
Have you got Audi pre-sense on your car?
Where in the UK?
Posted: Fri Jan 07, 2022 2:48 pm
by wellzieRS4
yeah its got pre sense, im in swindon
