Question for those on KW V3 (RS4)
Posted: Wed Mar 03, 2021 11:58 am
by Avantgarde
Those of you on KW V3 on your RS4, would you say it is more comfortable than stock (non-DRC) or harder than stock?
I feel that the comfort for the stock suspension on the highway and minor bumps is pretty good, but when it needs a little more travel the bump stops come in early and can get quite jarring. I see that the KW V3 has increased suspension travel of 5mm as well as shorter bump stops, so I am making an educated guess that they might even be more comfortable than stock non-DRC suspension.
Would be great if those of you on KW V3 could comment your first hand experience. But if you came from DRC suspension, then that’s a different matter cos I’ve driven a DRC equipped car and that is pretty plush in comfort mode.
Re: Question for those on KW V3 (RS4)
Posted: Wed Mar 03, 2021 5:58 pm
by Pturner3
Of course, it does depend on the adjustment of compression and rebound settings. That being one of the main advantages of the V3 - to be able to change those.
I tried my car using a few different settings. In recommended settings from KW I recalled there was no reduction in comfort - but better control. I prefer a harder setup than recommended though, and I still think the ride quality is good. What I never liked about having DRC or Adaptive Dampers in previous cars was the constant urge I felt to fiddle with the drive select. With the fixed set-up you just drive and forget about it. Less is more sometimes...!
I really like the V3s. With the stock suspension the car's front end would lift under acceleration like some 1980s Sierra - awful! The V4's would have been good to try, but were twice the price and I couldn't justify it with my usage (all-road, no track).
Have never tried setting the comp/re-bound to softer than recommended settings, but I would imagine the comfort would easily be retained.
Posted: Thu Mar 04, 2021 1:50 am
by Avantgarde
Pturner3 wrote: ↑Wed Mar 03, 2021 5:58 pm
Did your car come with DRC from factory or the standard sports suspension?
Posted: Thu Mar 04, 2021 9:19 am
by Pturner3
It came with the standard sports suspension.
