Gasoline Particulate Filter (GPF)
Posted: Fri Jan 18, 2019 10:59 pm
by Iannorwich
Does the B9 have a Gasoline Particulate Filter (GPF)?
Re: Gasoline Particulate Filter (GPF)
Posted: Sat Jan 19, 2019 12:21 am
by PieterZ
No but I won’t be surprised if the new run has one fitted.
Posted: Sat Jan 19, 2019 9:21 am
by Brooner
I think i would be looking at removing it if they fit it to the new production model
Unless this would negate the warranty
Posted: Sat Jan 19, 2019 9:22 am
by doodlebug
It’s not going to be a device you can just remove!
Posted: Sat Jan 19, 2019 9:36 am
by Brooner
Ah ok
I know some diesel owners have removed there particulate filter and re maped the ecu the fool the car that it is still in place
Probably be harder with newer cars
Posted: Sat Jan 19, 2019 9:58 am
by Markp
It will be part of the cat set up presumably.
Posted: Sat Jan 19, 2019 10:36 am
by doodlebug
Brooner wrote:Ah ok
Yes, and it’s an MOT fail. So remove under warranty and the warranty is gone or remove post and fail MOT.
Posted: Sat Jan 19, 2019 1:38 pm
by Brooner
Right so if the new one has on ill be leaving alone
Posted: Sat Jan 19, 2019 2:14 pm
by RS Owner
The updated model is almost certain to have one. I know one was fitted to the M4 last summer and the fact that the M3 did not have a GPF caused BMW to stop production earlier than they wanted to.
Posted: Sat Jan 19, 2019 7:54 pm
by PieterZ
I’m curious about hp too...
Posted: Sat Jan 19, 2019 8:17 pm
by Terminator_X
I thought that the RS4 was already compliant, no?
TX.
Posted: Sun Jan 20, 2019 2:03 pm
by 535dboy
I’m following this
Soon to order the Mrs a new car (Porsche again) and told that it will have GPF
Are theses going to cause the same issues as the diesel variants cause if the car doesn’t warm enough / get decent run do we know. ?
Posted: Sun Jan 20, 2019 2:34 pm
by s4tokyo
Not a precise confirmation to your query, because Audi's Media release only describes the intent to apply Particle Filters not the application timing by model, but FWIW -
"... To comply with the new limits, gasoline engines must be fitted with particulate filters. Their first use at Audi is slated for the Audi A5 Coupé 2.0 TFSI from June 2017 and they will later be gradually extended to all other series. In the future, Audi will be conducting all consumption and emission measurements with spark ignition engine particulate filters, as in accordance with the RDE legislation. ..."
https://www.audi-mediacenter.com/en/tec ... tions-8760
Posted: Mon Jan 21, 2019 12:05 pm
by kmpowell
I picked up a brand new petrol car at the start of the month, which has a GPF fitted. From my research it would appear the manufacturer started fitting GPFs to the model at the start of 2018 (way before WLPT shutdown). The model car I have pre WLTP had CO2 Emissions of 144g/km, my post WLTP car has 140g/km, but that isn't to do with the GPF.
The WLTP shutdown therefore is a co-incidence in some cases, however, VAG brands are indeed using it as an opportunity to add the GPF to their engines to further help them pass WLPT with better numbers, so the RS4 may appear with one if Audi see fit.
There aren't any problems with GPF's anyway as their are no heat issues, like there is with Diesel, for them to block or go wrong.
