So started the RS this morning from cold whilst loading the car with rubbish for the dump.
I noticed that there was only exhaust output from the left side pipe, I put my hand down to the RH side pipe and there was nothing at all. So aside from the valve flaps I can see in the tail pipes - there must be more plumbing further back I guess.
The car has the sports exhaust option.
Is the exhaust behaviour normal?
Curious exhaust behaviour on start up
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Re: Curious exhaust behaviour on start up
Doesn't the RS3 do something similar?
In the 3 the left pipe is open at idle and the right one doesn't open until about 4k revs. It's to keep the neighbours happy ish at startup / idling / low speeds. Maybe the 4 is the same?MikeFish wrote:Doesn't the RS3 do something similar?
TX.
I cold started my RS5 (sports exhaust) (it's 13@C here) and the exhaust gas is left side only, the valves that are visible are closed both sides.
I only ran the engine for 30 seconds and at idle, I assume right side will open later but I didn't wait because it's tipping it down here so I came back inside.
Gone : 2017 M3 CP
Gone : 2007 B7 RS4 ( )
Gone : 2017 M3 CP
Thanks RS5 owner - appreciated.
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
Gone, 2018 B9 RS4
Gone, 2015 8U RSQ3
