Suzukagrau Metallic
Posted: Thu Mar 08, 2018 9:46 pm
New colour on the Configurator, is this the “Storm Tropper” white?
Suzuka Grey Exclusive? Any colour is available if your pockets are deep enough!Iannorwich wrote: ↑Thu Mar 08, 2018 9:46 pmNew colour on the Configurator, is this the “Storm Tropper” white?
Exactly, if you are going to pay that much money at least have a special or different colour.Ian_C wrote:Suzuka Grey Exclusive? Any colour is available if your pockets are deep enough!Iannorwich wrote: ↑Thu Mar 08, 2018 9:46 pmNew colour on the Configurator, is this the “Storm Tropper” white?
Kingfisher Blue, Cornflower Blue, Byzanz Purple, Velvet Purple, Venetian Violet.noidea wrote: ↑Thu Mar 08, 2018 10:06 pmExactly, if you are going to pay that much money at least have a special or different colour.Ian_C wrote:Suzuka Grey Exclusive? Any colour is available if your pockets are deep enough!Iannorwich wrote: ↑Thu Mar 08, 2018 9:46 pmNew colour on the Configurator, is this the “Storm Tropper” white?
Sent from my Nexus 6P using Tapatalk
On the production line for the RS4 the paint tooling is setup with the colours from the palette given to that specific model. If a RS4 is specced with Exclusive/Individual paint then it goes into a separate process. They are painted totally separately from the standard production run, and paints have to loaded into fresh tooling, which is why it's all costlier.
I guess they have to start with a set of colours as you say.kmpowell wrote:On the production line for the RS4 the paint tooling is setup with the colours from the palette given to that specific model. If a RS4 is specced with Exclusive/Individual paint then it goes into a separate process. They are painted totally separately from the standard production run, and paints have to loaded into fresh tooling, which is why it's all costlier.
It’s likely you won’t see atandard colours added, only swapped/renamed at various MY lifecycle updates.noidea wrote: ↑Fri Mar 09, 2018 11:01 amI guess they have to start with a set of colours as you say.kmpowell wrote:On the production line for the RS4 the paint tooling is setup with the colours from the palette given to that specific model. If a RS4 is specced with Exclusive/Individual paint then it goes into a separate process. They are painted totally separately from the standard production run, and paints have to loaded into fresh tooling, which is why it's all costlier.
I suppose we will see more colours added to the list as time goes by.
Makes some sense but for some of the so called exclusive colours will be more common options on other cars.kmpowell wrote: ↑Fri Mar 09, 2018 10:47 amOn the production line for the RS4 the paint tooling is setup with the colours from the palette given to that specific model. If a RS4 is specced with Exclusive/Individual paint then it goes into a separate process. They are painted totally separately from the standard production run, and paints have to loaded into fresh tooling, which is why it's all costlier.
You're thinking of this too literally/simply. On its own, Suzuka Grey is not an "exclusive colour", it's only an exclusive colour when applicable to the RS4 because the RS4 is not available in Suzuka Grey in the normal RS4 colour palette. The same goes for Ara blue, it's not an exclusive colour on the RS3/TTRS because it's in the standard colour palette, but it is an exclusive colour when applied to the RS4.Grittle wrote: ↑Fri Mar 09, 2018 2:35 pmMakes some sense but for some of the so called exclusive colours will be more common options on other cars.kmpowell wrote: ↑Fri Mar 09, 2018 10:47 amOn the production line for the RS4 the paint tooling is setup with the colours from the palette given to that specific model. If a RS4 is specced with Exclusive/Individual paint then it goes into a separate process. They are painted totally separately from the standard production run, and paints have to loaded into fresh tooling, which is why it's all costlier.
My B8 is Suzuka Grey and it wasn’t an exclusive. It is fairly rare but I do see other VAG products in this colour
