Wheel Spacer's
- wellzieRS4
Wheel Spacer's
Has anyone fitted wheels spacers to their car, if so what sizes have you fitted, I've see a few posts people going wider on the back, like 20mm back,15mm front or 15mm back, 10mm front.
Im not sure on staggering them, id would of thought keeping sizes same front and back would be better but I'm not sure
Any opinions or pictures would be great
Im going to be fitting MSS adjustable springs too
- wellzieRS4
Re: Wheel Spacer's
On another subject i got Google Earth back on today, only cost £25 .......... Which was nice
Re: Wheel Spacer's
im sure some one here did spacers on the standard wheels but i cant find the thread
an easy way would be place a peace of wood against the wheel up to the arch and mark he distance measure it then that would be the max spacer keeping the tyre inside the arch
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
Re: Wheel Spacer's
Exactly what I do as well
2022 RS4 - Turbo Blue / Black
Gone: 2018 RS4 - Navarra Blue / Black, 2016 A6 BiTDI - Midnight Blue / Black, 2016 Golf GTD with a "lot" of toys, 2016 M3 CP - Mineral Grey / Black, 2009 135i - Le Mans Blue / Black
- wellzieRS4
Re: Wheel Spacer's
Good idea
Re: Wheel Spacer's
I run 19s with 10mm all round. Perfect for me, and doesn’t look like I am trying too hard.
Re: Wheel Spacer's
How?wellzieRS4 wrote: ↑Tue Jan 18, 2022 8:15 pmOn another subject i got Google Earth back on today, only cost £25 .......... Which was nice![]()
- wellzieRS4
- wellzieRS4
Re: Wheel Spacer's
From a company called MAk Coding, they sent me the files and I put them on a SD card and updated it, it was easy I also got speed camera alerts file off them for £30Markp wrote: ↑Thu Jan 20, 2022 7:43 amHow?wellzieRS4 wrote: ↑Tue Jan 18, 2022 8:15 pmOn another subject i got Google Earth back on today, only cost £25 .......... Which was nice![]()
Works a treat but you need to have a active Audi connect subscription
Re: Wheel Spacer's
This one?wellzieRS4 wrote: ↑Thu Jan 20, 2022 10:00 amFrom a company called MAk Coding, they sent me the files and I put them on a SD card and updated it, it was easy I also got speed camera alerts file off them for £30Markp wrote: ↑Thu Jan 20, 2022 7:43 amHow?wellzieRS4 wrote: ↑Tue Jan 18, 2022 8:15 pmOn another subject i got Google Earth back on today, only cost £25 .......... Which was nice![]()
https://www.makcoding.co.uk/
- wellzieRS4
Re: Wheel Spacer's
Yeah that's itrjwojcik wrote: ↑Thu Jan 20, 2022 3:55 pmThis one?wellzieRS4 wrote: ↑Thu Jan 20, 2022 10:00 amFrom a company called MAk Coding, they sent me the files and I put them on a SD card and updated it, it was easy I also got speed camera alerts file off them for £30
Re: Wheel Spacer's
Don't know bore size. I used Bimmec (TUV approved) - this sort of thing: https://www.ebay.co.uk/itm/333371543119 ... %3A2047675wellzieRS4 wrote: ↑Thu Jan 20, 2022 9:57 amWhat spacers have you fitted and where did you get them
I’m struggling to find any that fit B9 RS4
Do you know what the centre bore size is
Re: Wheel Spacer's
CM Wheels also supply Bimmec, but the ebay ad looks perfect to me. Or contact a supplier and tell them what you've got and what spacer you need.
From the notes I made when looking:
The wheels for the RS4(B9) use a PCD of 5x112, centre bore 66.5mm and M14x1.5 bolt.
Standard bolt is M14x1.5 R13 27mm thread, 17mm hex.
Don't forget to get a set of new locking wheel nuts as well?
What wheels have you got? If standard RS4 wheels, they all have different offsets, so would potentially require different spacers.
- wellzieRS4
Re: Wheel Spacer's
Ive got carbon edition so its got 20in 5 spoke milled wheels, so the centre bore is 66.5mm but all the spacers i can find seem to be 66.6mm, would this be ok , when I've added my vehicle on eBay and some other sites they don't seem to come up with anything compatible or maybe I'm missing somethingrjwojcik wrote: ↑Sun Jan 23, 2022 7:43 pmCM Wheels also supply Bimmec, but the ebay ad looks perfect to me. Or contact a supplier and tell them what you've got and what spacer you need.
Re: Wheel Spacer's
ET22 then... I'm using 10mm spacers on mine and they're the 66.6 ones.
I sent an email to email CM Wheels, with the following:
Hi
I'd like to order a set of 4 10mm wheels spacers, with bolts, locking wheel bolts and 2 keys, all in black. The website only allows for one key.
To fit the following reg: ???????
Many thanks.
Kind regards
Hi
Many thanks.
Kind regards
Users browsing this forum: Google Adsense [Bot] and 43 guests
