Head Up Display Retrofit - A4 B9 8W
2.9 V6 24v TFSI - 444 bhp
Pturner3
Post by Pturner3 » Mon Mar 08, 2021 12:41 am
Hi,
Has anyone any experience with retrofitting Head Up Display KS1 to A4 B9? My car is 2019 Sport Edition RS4.
I have VCP, HEX-NET and current flow diagrams, workhop manual.
Looking into this the hardware side looks fairly straight forward:
Dash: 8W2857001J
HUD unit with integrated contorl module (J898): 8W5919617C
Light switch for HUD adjustment: 4M0941531P
New windscreen - lets place this requirement aside for now...
Looking at the current flow diagrams, there doesn't appear be too much wiring to connect. Would be interested to seek advice, and also on coding, using 2nd hand HUD, HUD calibration etc...
Thanks,
Phil
Pturner3
Re: Head Up Display Retrofit - A4 B9 8W
Post by Pturner3 » Tue Jun 29, 2021 5:58 am
Done
rjwojcik
Post by rjwojcik » Tue Jun 29, 2021 7:24 am
Wow, well done
2022 RS4 - Turbo Blue / Black
Gone: 2018 RS4 - Navarra Blue / Black, 2016 A6 BiTDI - Midnight Blue / Black, 2016 Golf GTD with a "lot" of toys, 2016 M3 CP - Mineral Grey / Black, 2009 135i - Le Mans Blue / Black
RS Owner
Post by RS Owner » Tue Jun 29, 2021 11:16 am
I never realised that HUD equipped cars have a different windscreen. Learn something everyday :D
Gone : 2017 M3 CP
elchet
Post by elchet » Thu Jul 01, 2021 2:39 pm
Would you be up for sharing learnings, and any photos of the process if you have them?
2018 B9 RS4 Daytona Grey
rjwojcik
Post by rjwojcik » Sat Jul 10, 2021 4:02 pm
Would you know if you can configure what is shown on the standard and sport HUD display?
Pturner3
Post by Pturner3 » Sun Jan 02, 2022 8:03 pm
Apologies, I'm not here often as you can tell!
I have a full write-up guide if anyone wants it... Pm me.
wellzieRS4
Post by wellzieRS4 » Fri Jan 07, 2022 12:09 pm
Have you retro fitted B & O
Pturner3
Post by Pturner3 » Fri Jan 07, 2022 12:29 pm
Hi,
No I haven't, sorry. Best place to start is an official parts website to see what you need. And then get hold of the current flow diagrams to check connections. Is your car a UK vehicle?
It can be quite involved to research what is required for retrofits, as other components can be affected and may not be compatible without upgrade too.
Look up PR codes for the equipment you want to fit. Then use current flow diagrams to see all the modules and components the system connects to. Then go to parts manual and find out all the parts needed that are unique to the PR code of the equipment you want to fit. Lots of back and forth and tracing things out. Often it may not be economical unless you can get everything second hand. It's not always as simple as just buying the B&O parts for example... But I don't know. There are just quite a few considerations..
wellzieRS4
Post by wellzieRS4 » Fri Jan 07, 2022 12:40 pm
Hi,
Cheers, it does look like its probably not worth the hassle tbh, i wouldn't have a clue about flow diagrams i paint cars for a living, i might look at upgrading the speakers aftermarket and fit B & O speaker covers maybe
The spec aint to bad on my car and had most things i wanted but had to compromise with B & O, do you know if road speed sign recognition is easy to do, i have head up display
Pturner3
Post by Pturner3 » Fri Jan 07, 2022 12:44 pm
Are you from the UK?
TSR needs front camera, firmware update and coding.
wellzieRS4
Post by wellzieRS4 » Fri Jan 07, 2022 1:42 pm
Yeah I’m in the uk, will my car have the camera
Pturner3
Post by Pturner3 » Fri Jan 07, 2022 2:33 pm
Have you got Audi pre-sense on your car?
Where in the UK?
wellzieRS4
Post by wellzieRS4 » Fri Jan 07, 2022 2:48 pm
yeah its got pre sense, im in swindon
Users browsing this forum: Google Adsense [Bot] and 42 guests
