Wheel nut torque sttings
Munchingmolar
Anyone ? Seen various from 90 to 105 ft lbs !
Dannyboy123
- 1st Gear
Re: Wheel nut torque sttings
Audi spec for the RS4 is 120nm
Yep 120 nm just change to my summer wheels this is the torque setting i use and re check the torque after a 30 mile run
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
and 120 Nm is 90 lb-ft so the lower end of your estimate
Gone : 2017 M3 CP
Gone : 2007 B7 RS4 (
Gone : 2017 M3 CP
StewamEmiya37
Suppose you tighten the fasteners with less force than necessary, then under the influence of vibrations. In that case, the threaded connection can unwind without providing the necessary tightness between the fastened parts, which can lead to serious consequences. On the contrary, if you apply more force to the hardware than is required, the destruction of the threaded connection or the fastened parts will occur; for example, a thread failure or the appearance of cracks in the parts may occur. In addition, remember that you need to buy special bolts. I recommend a store where I always buy power tool accessories and hardware. I think you'll find everything you need there.
There you go 120nm from the owners manual
Users browsing this forum: No registered users and 52 guests
