Exhaust Valves Disabled
Just unplugged the connectors to the exhaust valves and wow! what a difference it makes. Car should of sounded like it from factory. There is a slight droan at motorway speeds, but I normally have the music on reasonably loud that its barely audible. It can rattle the inside of the car a little if you put your foot down a little bit at under 2000rpm. Thinking about getting one of those miltek (or other brand) boxes that allow you to control the exhaust valves yourself rather than having them permanently open.
Re: Exhaust Valves Disabled
Am I missing something? You can customize the settings, one of them is flaps open.
All black B9 RS4
If you mean on the MMI then they are not always open, they still close at certains revs. Disconnecting them means they are open at all revs all the time and regardless of Drive Select mode.
How do you do this? Ta
Macan GTS
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Golf GTi Mk 1, Mk 2, Mk 3, Mk 4, VR6,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
Boxster S
Previously
Audi RS4 B8
Audi S4 B8
Audi S4 B6
Nissan GTR,
Lotus Elise 111R,
Caterham,
Various SAAB Turbos
Peugeot 205 GTi,
RS2000
Disconnect the plug from the exhaust valves.
Should the electrical connector just pull off or is there some sort of catch you need to release as mine won’t budge! Thanks
Yes there is a little catch to stop it vibrating off. I think someone had a photo of it on here recently, but it might have been in the RS6 forum.
Magic - thanks
Its the same type of connectors used on plugs in the engine bay. Have a look at the connectors in there to see how it works.
Hi guys, my back right flap makes a rattle noise & open & closes, the other side stays shut. Is this normal? It’s under warranty
I have the same issue. I have an appointment with the dealer Monday they said it could be a problem with the electric motor. Right hand side for me as well. Mmh
Users browsing this forum: initiala4 and 7 guests
