Gasoline Particulate Filter (GPF)
Does the B9 have a Gasoline Particulate Filter (GPF)?
Re: Gasoline Particulate Filter (GPF)
No but I won’t be surprised if the new run has one fitted.
All black B9 RS4
I think i would be looking at removing it if they fit it to the new production model
Unless this would negate the warranty
2018 B9 RS4 Navarra Blue
2013 B8 RS4 Sepang Blue
2007 B7 RS4 Avant Sprint Blue
2001 B5 RS4 Nogaro Blue
1993 B4 S2 Avant laser Red
It’s not going to be a device you can just remove!
Ah ok
I know some diesel owners have removed there particulate filter and re maped the ecu the fool the car that it is still in place
Probably be harder with newer cars
It will be part of the cat set up presumably.
Yes, and it’s an MOT fail. So remove under warranty and the warranty is gone or remove post and fail MOT.Brooner wrote:Ah ok
Right so if the new one has on ill be leaving alone
The updated model is almost certain to have one. I know one was fitted to the M4 last summer and the fact that the M3 did not have a GPF caused BMW to stop production earlier than they wanted to.
Gone : 2017 M3 CP
Gone : 2007 B7 RS4 (
Gone : 2017 M3 CP
I thought that the RS4 was already compliant, no?
TX.
TX.
I’m following this
Soon to order the Mrs a new car (Porsche again) and told that it will have GPF
Are theses going to cause the same issues as the diesel variants cause if the car doesn’t warm enough / get decent run do we know. ?
Currently :
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
Seat Ibiza excellence Lux!
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2017 AMG E class wagon
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Porsche 992S
Porsche Cayenne GTS
Porsche GT4 RS
1987 Porsche 928S4
1967 Jaaag Mk2 3.4
Ex
2012 Audi RS4 (B8)
Not a precise confirmation to your query, because Audi's Media release only describes the intent to apply Particle Filters not the application timing by model, but FWIW -
"... To comply with the new limits, gasoline engines must be fitted with particulate filters. Their first use at Audi is slated for the Audi A5 Coupé 2.0 TFSI from June 2017 and they will later be gradually extended to all other series. In the future, Audi will be conducting all consumption and emission measurements with spark ignition engine particulate filters, as in accordance with the RDE legislation. ..."
https://www.audi-mediacenter.com/en/tec ... tions-8760
Current :Sonoma Green. Ext Black Pack, Carbon 'Ext/Eng Cover/Int trim', Sports Exhaust, RS Sports Int., Pana Sunroof, Matrix Lights, Park & Drive Assist pkg., Speed limiter removed, Titanium-Anthracite 20".
Previous : B8.5 RS4 Daytona Gray
Previous : B8 S4 Ibis White
I picked up a brand new petrol car at the start of the month, which has a GPF fitted. From my research it would appear the manufacturer started fitting GPFs to the model at the start of 2018 (way before WLPT shutdown). The model car I have pre WLTP had CO2 Emissions of 144g/km, my post WLTP car has 140g/km, but that isn't to do with the GPF.
The WLTP shutdown therefore is a co-incidence in some cases, however, VAG brands are indeed using it as an opportunity to add the GPF to their engines to further help them pass WLPT with better numbers, so the RS4 may appear with one if Audi see fit.
There aren't any problems with GPF's anyway as their are no heat issues, like there is with Diesel, for them to block or go wrong.
'15 B8 RS4 - SOLD
Users browsing this forum: RS Owner and 35 guests
