Private Messages
Posted: Fri Apr 13, 2012 10:25 am
by bam_bam
I seem to have 2 PMs stuck even though I'm only using 61% of my inbox. Any thoughts?
Re: Private Messages
Posted: Fri Apr 13, 2012 11:04 am
by Teutonic Tuner
in your outbox? If so that means they haven't been read by the recipient doesn't it?
Posted: Fri Apr 13, 2012 11:47 am
by bam_bam
No. I understand how PM and bb works.
My problem is this:
Folder is 60% full (119 from 200 messages stored)
You have 2 private messages currently on hold because of full folder.
Release all on-hold messages… they will be re-sorted into the appropriate folder if enough space is made available.
Posted: Fri Apr 13, 2012 11:52 am
by Timster
Isn't it a bit bleedin' obvious Bam:
The 2 stuck messages have massive porn attachments and therefore can't be released.
Maybe suggest to the sender that they either re-encode at a lower res, or cut out some of the animal scenes.
Footlong, are you listening ?
Posted: Fri Apr 13, 2012 11:59 am
by bam_bam
TimsterRS4 wrote:Isn't it a bit bleedin' obvious Bam:
Mr. Footlong uses SFTP to send my daily porn, it must be someone else...
Posted: Fri Apr 13, 2012 12:12 pm
by Timster
Shagga? It's the sort of thing he'd do (the blithering idiot).
Edit: No, make that Kiwi..... it's so obvious when you think about it.
Posted: Fri Apr 13, 2012 12:41 pm
by bam_bam
TimsterRS4 wrote:Shagga? It's the sort of thing he'd do (the blithering idiot).
Tim, you are so right that it's wrong.
Of course, a filthy Kiwi sending sheep-shagging porn to a decent Australian, I don't know how I didn't see that one.
@ Kiwi: I've found it best to encode sheep porn in 3gp format with a 10x10 pass for the spot-level brightness filter. You need to use that because there's just too much white wool in each scene, unless, of course you're trying to shift me some interracial (black sheep on farmer OR Maori man on white sheep). If that's the case, use a 5x5 multi-pass filter. Please name the files sequentially from the "Justin Bieber - My World" album.
Cheers mate.
Posted: Fri Apr 13, 2012 1:17 pm
by HYFR
just sent you one bam ... no porn im afraid
Posted: Fri Apr 13, 2012 1:42 pm
by Timster
bam_bam wrote:TimsterRS4 wrote:Shagga? It's the sort of thing he'd do (the blithering idiot).
Cheers mate.
Laugh about on the floor or something.
Posted: Fri Apr 13, 2012 5:55 pm
by amanda1
bam_bam wrote:No. I understand how PM and bb works.
My problem is this:
I have the same bam only I have 4 held that way........and mine are not porn either!!!
Posted: Fri Apr 13, 2012 6:41 pm
by Mr V10
You could always try texting/calling Bam instead, Panda.
Posted: Fri Apr 13, 2012 7:09 pm
by bam_bam
Amar wrote:You could always try texting/calling Bam instead, Panda.
Amar, Ima gunna crush your hand next time I shake it.
Posted: Fri Apr 13, 2012 7:20 pm
by Mr V10
I would say that is more then fair, and I would say I am getting off lightly consdering.
Posted: Fri Apr 13, 2012 10:16 pm
by Mr Footlong
bam_bam wrote:Mr. Footlong uses SFTP to send my daily porn, it must be someone else...
Pfft, only because you are too fecking cheap to pay for newsgroup access.
