Als RS6
Re: Als RS6
Post by MikeFish » Fri Dec 21, 2018 4:21 pm
Looks good already.
The rings are not too difficult. If you have some plastic trim removal tools it's pretty straight forward.
As you mentioned the CETE module I assume you are in air? If so it is sold as Milltek in the UK so easier to get hold of than the CETE. You can also lower using VCDS and also just use some little plastic arms that clip onto the level sensers and trick the car into thinking it is higher than it actually is so the car lowers itself a bit. They are cheap, adjustable and easy to fit. Some use VCDS to lower it then add the arms for a bit more lows.
alfrs6
Re: Als RS6
Post by alfrs6 » Fri Dec 21, 2018 5:18 pm
Thanks guys, happy how it’s looking, the dechrome certainly made a big difference
That’s good to know, I had seen a few people mention that it was a bumper off job for the rings.
Yes air suspension, I may very well down the line end up on aftermarket bags so might look into the cheap and easy option to get some lows for now
Current
2016 RS6 C7
2016 Nissan Navara
2012 Triumph Daytona
1999 E36 Drifter
1998 E36 S54 Drifter
Previous
2014 Nissan GTR
2011 Audi S3
2003 BMW M3
Sedge5
Re: Als RS6
Post by Sedge5 » Sun Dec 23, 2018 12:27 am
alfrs6 wrote:
Fri Dec 21, 2018 12:51 pm
Cars ready for pick up now after having tints, dechrome and some Ispiri wheels. Few little things to add when it’s picked up, black Center caps, black rings, rear wiper delete and some carbon wing mirrors.
How easy is it to get rings and RS6 off the front?
Needs to be lowered, seen the Cete module mentioned mostly so probably pick one of them up in the new year. Any other alternatives?
Coming along nicely..... :bowdown:
RS6 C7 PE - current
S6 C7 Avant - too hesitant, not enough power
A6 C7, 2.0 TDI......aghhhhh
A3 , 2.0 BE, tdi, yeahhh...
Return to “Readers' Rides”
Users browsing this forum: JamesBaby and 61 guests
