Some Great New Mods
Posted: Sun Mar 30, 2008 9:08 am
by GrahamS4
RE: Some Great New Mods
Posted: Sun Mar 30, 2008 10:26 am
by Harper--D
"Engine Oil Bypass Kit"
"Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block? KaleCoAuto bypass kit comes with everything you need to run the oil around your motor block where it will do more good. Oil runs cooler, and as a result, there may be horsepower gains!" :shock:
Posted: Sun Mar 30, 2008 10:29 am
by Harper--D
Imagine if they were for real "why stop at cross drilled discs, now we have cros drilled brake lines... almost immediatly your hot brake fluid will be met with cold air"
Posted: Sun Mar 30, 2008 10:33 am
by Philws4
Think this should of been posted up on tuesday :lol:
Posted: Sun Mar 30, 2008 5:36 pm
by Blue_Thunder
"Blinker Fluid"
Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, factory quality blinker fluid should be changed every 150,000 blinks.
:lol:
Posted: Mon Mar 31, 2008 10:37 am
by derdle
Doug had better watch out...this lot have adjustable power bands!
Posted: Mon Mar 31, 2008 9:28 pm
by CliveH
Nice find Graham :thumbs:
I've just ordered a bottle of their Engine Scrub - only $9.99
"Is the inside of your motor dirty? Most likely! Some people will tell you the only way to clean your motor is to tear it down and rebuild it. This is no good!!! KaleCoAuto internals cleaner is a special combination of iron, graphite, and copper shrapnel of assorted sizes that work to sand and polish the inside of your motor! Add 2oz per quart of oil in your car. New engine clean shrapnel should be used at every oil change! Bottle includes pouring mechanism. Comes in 16oz packages. Do not injest. Contact a physician immediately if injested, do not induce vomiting."
