Fitting S4 badge to RS4 grill --- How ?
Posted: Mon Mar 17, 2008 2:59 pm
by dr_wimpkins
Just fitted an RS4 grill to my puppy, but cant see an easy way of attaching the standard S4 badge to it.
Do I have to glue it?
Doc W
RE: Fitting S4 badge to RS4 grill --- How ?
Posted: Mon Mar 17, 2008 3:00 pm
by SimonS4MTM
Mine is cable tied from the back
Posted: Mon Mar 17, 2008 3:39 pm
by Blue_Thunder
There was an AW write-up which involved using bits of meccano.
I'd fitted mine with cable ties as well, but found that it got loose over time. Got bored having to redo it a few times, so now it's debadged!
I'll get around to it one day...
Posted: Mon Mar 17, 2008 4:03 pm
by jeffw
I went lo-tech and used a small woodscrew....worked theough
Posted: Mon Mar 17, 2008 6:20 pm
by dr_wimpkins
Nice 1 lads !
Posted: Mon Mar 17, 2008 8:02 pm
by Ads4
Presuming you've got ye old badge....
http://www.audiworld.com/tech/ext31.shtml
If you've got the newer one, I can only suggest superglue!
Posted: Mon Mar 17, 2008 11:22 pm
by Matt_H
I trimmed the excess plastic off the fixing bits, then used some 'no more nails' exterior stuff - worked a treat
Posted: Mon Mar 17, 2008 11:39 pm
by mikeyquattro
IIRC I trimmed it down to suit and clipped it on. Bobbler should know, he now owns it!!
Posted: Tue Mar 18, 2008 12:38 am
by rolskii
mikeyquattro wrote:IIRC I trimmed it down to suit and clipped it on. Bobbler should know, he now owns it!!
I used the clips on mine too .... some way or other ... if in doubt - get the araldite out .....
Posted: Tue Mar 18, 2008 10:15 pm
by Philws4
Posted: Tue Mar 18, 2008 10:26 pm
by Virdee Autos
I'm not going to bother reading the AW articles, so pardon me if it's already been mentioned, but heres another way. Used this twice now, and never failed!
Get the badge, and cut off the excess tabs at the back, so that your basically left with 2 lugs either side. Do this whilst checking it will fit the grille/mesh and place the badge were you want it, i.e. making sure it fits everytime.
Then once you've got 2 suitable lugs, place it where you want it on the grille, and heat up the 2 tabs with a heat gun or something appropriate. Get them hot enough, so you can bend them, i.e. flexible. Then once they're like this....bend them against the grille backing, and quickly place it under cold water, or alternatively keep some water and cloth nearby to do this.
Job done!
