Boost Drop - What could be the cause?
Posted: Tue Mar 11, 2008 12:38 am
by rs-mad
Hi,
Just looking for some ideas that you guys may have as to why my boost curve has dropped off as opposed to holding boost as it normally does?
The image attached shows what the boost curve should be and what is it.
I have a feeling it is a boost leak and will be looking at the fuel trims later today but just want to know if anyone has seen anything like this before I go looking
Thanks in advance.
RS-MAD
RE: Boost Drop - What could be the cause?
Posted: Tue Mar 11, 2008 12:56 am
by S2tuner
I don't think it's a leak, as the boost you're holding at redline is identical to the "normal" curve.
Posted: Tue Mar 11, 2008 1:06 am
by rs-mad
S2Tuner - Thanks for replying.
What you say does make sense as the requested boost for both curves is pretty much the same.
But boost has dropped off at 3500rpm as opposed to holding until ~5000rpm.
RS-MAD
Posted: Tue Mar 11, 2008 1:49 am
by flashyg
Boost controllers get tired. try changing usually clears up this mid drop issue.
Posted: Tue Mar 11, 2008 1:53 am
by rs-mad
You mean the N75 valve?
RS-MAD
Posted: Tue Mar 11, 2008 4:29 am
by rs-mad
Just went a and logged:
MB032 (Stored and Idle Values)
MB033 (Idle values)
RS-MAD
Posted: Tue Mar 11, 2008 9:48 am
by Nige_RS4
When you say normal and not normal, do you mean requested and actual or are you comparing a boost log from a different day? If from a different day, then there could be any number of factors that could change your boost curve slightly. There doesn't seem to be any units of measurement on the vertical axis?
Posted: Tue Mar 11, 2008 11:18 am
by rs-mad
Nige - The boost decrease has been more than what would normally occur on a day to day.
See new curve
Normal = What boost should be
Not Normal = What boost is and shouldnt be
RS-MAD
Posted: Sat Mar 15, 2008 8:29 am
by rs-mad
Problem diagnosed
RS-MAD
Posted: Sat Mar 15, 2008 10:22 am
by Blue_Thunder
What was the issue?
And i'm still unclear what you meant by your 'Normal' boost curve. As Nige asked, was this what you've previously logged as your actual boost on the car, or was this the specified boost?
