Wanted: Tool to remove valves and springs
Posted: Sun Feb 24, 2008 8:35 pm
by viperbl
I need to get hold of the tool to remove and fit the intake and exhaust valves/springs on my rs4 and 2.4 heads ...
Does anyone have any that I can buy/borrow or know where I can get some??
Cheers,
Rich.
RE: Wanted: Tool to remove valves and springs
Posted: Sun Feb 24, 2008 9:00 pm
by Doug_S2
halfords!
Posted: Sun Feb 24, 2008 9:03 pm
by Doug_S2
on second thoughts - what are you doing with the heads? and are they new 2.4 heads?
Posted: Sun Feb 24, 2008 9:26 pm
by viperbl
Plan is to use the 2.4 heads on the engine instead of the RS4 heads ... they are second hand, just trying to clean them up, get the valves/springs etc out, going to get stronger springs for them ... maybe a new cam if I can afford it ...
Posted: Sun Feb 24, 2008 10:01 pm
by Doug_S2
i would advise you to get the heads pressure tested and if you are doing that just send the heads off to a good machine shop to do all the work (pressure test, check guides, replace seals, check guides, recut the seats, and just check everything!) the last hing you wnat ot do is putit back together and a small thing means pulling hte engine again! You will need to use a machine shop for getting your crank balanced to your rods anyway.
Re: RE: Wanted: Tool to remove valves and springs
Posted: Sun Feb 24, 2008 10:07 pm
by viperbl
I hear you, good advice Doug thanks ... I have a machine shop already sorted to do the balance, so I will see if they can also do the heads ...
Is it just a standard tool I need to remove the valves/springs etc then? at least I can get all the stuff out so I can get it cleaned up ... got a nice friend that said I can use his dishwasher to clean then
RE: Re: RE: Wanted: Tool to remove valves and springs
Posted: Sun Feb 24, 2008 10:10 pm
by Doug_S2
A standard tool will work if you get the small adapter for the small intake valves with it.
Posted: Sun Feb 24, 2008 10:56 pm
by s4woody
until you get the tool you can remove the valve springs by getting a socket that is the size of the spring caps..then using an extension on the socket place the socket over the spring and hit it with a hammer..the spring will compress quickly and release the collets..it will work and the spring wont fly up and smash you or anything..and no you wont damage anything..
Posted: Mon Feb 25, 2008 11:09 am
by viperbl
Cheers Woody! I will be trying this tonight
Posted: Mon Feb 25, 2008 11:50 am
by DavidT
Rich, can I move this to the Tuning & mod forum now ? contents seem more relevant for there.
Re: RE: Re: RE: Wanted: Tool to remove valves and springs
Posted: Mon Feb 25, 2008 11:53 am
by viperbl
DavidT wrote:Rich, can I move this to the Tuning & mod forum now ? contents seem more relevant for there.
Yea, good idea ...
RE: Re: RE: Re: RE: Wanted: Tool to remove valves and spring
Posted: Mon Feb 25, 2008 2:12 pm
by viperbl
Would something like this do for both the small and large valves on the engine ??
http://cgi.ebay.co.uk/NEW-Multi-Valve-S ... dZViewItem
Posted: Tue Feb 26, 2008 12:54 am
by S4
sykes pickervant do some nice ones.. you can get one with double ends.. big or small, Like Doug said.
Darren
Posted: Tue Feb 26, 2008 9:59 am
by viperbl
Cheers guys, and the socket and hammer work to get them out
