Page 1 of 2
CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!!!!!!!!!!!!!
Posted: Thu Feb 21, 2008 7:08 pm
by ZKNY
hey guys,
i came across this. its an intake manifold for our car. it looks stock, but is far from it. it is lightly ported, and has a much larger plenum. this will give the car way more air upstairs, where it is normally choked off.
take a look, i have a one-off model myself. you cannot find this anywhere. get it here first. if anyone has any questions, pls email or PM me.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 33105&rd=1[/url]
RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!!!!!!!!!
Posted: Thu Feb 21, 2008 7:35 pm
by dummi
how much boost have you run with it so far?
Posted: Thu Feb 21, 2008 7:58 pm
by s4woody
and what happens to the AUX water pump with all that extra depth..
Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!!!!!
Posted: Fri Feb 22, 2008 8:59 am
by ZKNY
s4woody wrote:and what happens to the AUX water pump with all that extra depth..
great question. it is either re-located. or better yet, removed!
RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!!!!!
Posted: Fri Feb 22, 2008 9:45 am
by DavidT
Moved to tuning & mods my me so everyone can see it & so we only have one thread running.
Posted: Fri Feb 22, 2008 10:13 am
by MarkB
ZKNY wrote:s4woody wrote:and what happens to the AUX water pump with all that extra depth..
I've been thinking about removing my aux pump. I've seen it mentioned a few times on Audiworld.
Does the extra plenum volume give any noticeable advantage?
Posted: Fri Feb 22, 2008 10:46 am
by tartan_rob
I am working a carbon reinforced with kevlar custom intake manifold for MRC. Similiar to the std design but much wider ports and more direct intake + about an 1/8 of the weight....
Posted: Fri Feb 22, 2008 11:36 am
by rikrose
MarkB wrote:ZKNY wrote:I've been thinking about removing my aux pump. I've seen it mentioned a few times on Audiworld.
I've been thinking about jumping off a bridge recently. I've seen a lot of people who own parachutes doing it, and they seem to have fun.
Is there a summary for the supposed benefits and losses in doing this, to save me having to search audiworld?
Posted: Fri Feb 22, 2008 12:27 pm
by MarkB
rikrose wrote:MarkB wrote:I've been thinking about removing my aux pump. I've seen it mentioned a few times on Audiworld.
I can't remember
Posted: Fri Feb 22, 2008 7:40 pm
by confusionhunter
I am also interested to know what advantage expanding the plenum gives.... I personally dont see theoretically that it is any advantage. In fact its a disadvantage as if more volume to compress.... Unless the std plenum is too small (which it might be) Plenums are supposed to be the same volume as the displacement of the engine....
Posted: Fri Feb 22, 2008 8:29 pm
by s4woody
well you'd proberbly get an adrenalin rush..(benefit) then if ya parachute dont open <beep> yourself (losses)
hope that helps..
Posted: Sat Feb 23, 2008 9:46 am
by ZKNY
yea, i removed mine. you just have to let the car sit a little longer if you run the car hard.
what do you think? =)
Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!!!!!
Posted: Sat Feb 23, 2008 9:52 am
by ZKNY
confusionhunter wrote:I am also interested to know what advantage expanding the plenum gives.... I personally dont see theoretically that it is any advantage. In fact its a disadvantage as if more volume to compress.... Unless the std plenum is too small (which it might be) Plenums are supposed to be the same volume as the displacement of the engine....
ding-ding-ding! somebody is on the right track!!! the stock plenum is too small. another reason why KO4's die off upstairs. with a larger plenum you have air all the way past the redline.
there may be a slight lag (200-500) rpms (depending on tune!!!), but once you get going, the tach will bounce off the redline. sooo much more air you wouldnt believe.
i know the gent who custom fabs em.
RE: Re: RE: Re: RE: CUSTOM INTAKE MANIFOLD- 1 of a kind!!!!!
Posted: Sat Feb 23, 2008 10:49 am
by confusionhunter
yep.... having a look at the plenum yesterday there is no way that is 2.7 litres of volume.... lucky if its 1.5 litres!
A sacrifice of cramming too much in there I guess!
Posted: Mon Feb 25, 2008 10:01 am
by tartan_rob
Surely a smaller plenum equates to much more responsive boost as less area to pressurize?
Is it simply a trade off of responsiveness against high boost levels?
