Page 1 of 2
Carbon inlet manifolds....
Posted: Wed Feb 13, 2008 11:35 am
by tartan_rob
Any interest in these?
Also thinking about designing and building a single piece intake pipe from the MAF into the turbo's...any interest?
Both for any S/RS model?
Am willing to put the time into development and mould making but only if the interest is sufficient.
RE: Carbon inlet manifolds....
Posted: Wed Feb 13, 2008 11:40 am
by Andiroo
Are you looking at a copy of oem intake manifold in carbon Rob, or something a bit tricker?
Cheers,
Andiroo
Posted: Wed Feb 13, 2008 12:18 pm
by JonnyX
I would think you would need a good unstanding of CFD to do this properly.
Posted: Wed Feb 13, 2008 2:43 pm
by tartan_rob
I am qualiifed in thermofluids and hydrodynamics so can have a good stab at this. As I'm going to be making the components myself, the costs to me are not so high, if it don't work I can re-tool and re-make without having to pay someone else to. That should keep my R&D costs down to a bare minimum.
Posted: Wed Feb 13, 2008 7:22 pm
by rikrose
Is it going to provide any reasonable gain, though? The propshafts I understand - inlet manifold.. not so. Can you explain how this would provide a reasonable benefit? Is there anything else you could think of that would benefit from being made form CF that would be likely to provide a better benefit?
Posted: Thu Feb 14, 2008 8:37 am
by AdamS4
Posted: Thu Feb 14, 2008 9:22 am
by tartan_rob
I think initially it is a weight saving exercise (and less heat soak for cooler/denser air) although if you are smart with the design of the moulds, you can get much better and more direct airflow. Its all about understanding the fluid dynamics. As for the increased gains....who knows. Time will tell. I would expect initially that the weight would be the immediate benefit coupled with better heat control. How much does a "normal" cast intake manifold weigh?
Initially I'd like to just create a copy that works to understand the pressures, then it is a pure R&D exercise to get the fluid dynamics right. I going to work with MRC if they will let me, to make a few parts and work with them on the development......
Posted: Thu Feb 14, 2008 8:48 pm
by spen
I'm interested, depending on cost.
Also fatter intake pipework down to the turbo inlet, if you want some ideas?!?
Posted: Thu Feb 14, 2008 9:36 pm
by Doug_S2
maybe we should do one of our dual throttle body inlet manifolds in CF - i'll talk to you about this next week rob.
Posted: Thu Feb 14, 2008 10:08 pm
by rikrose
Now it's been mentioned, I've been wanting to ask about that since you pointed out the second throttle body on your car. I've been resisting the urge to ask about it until you mentioned it in public.
Posted: Thu Feb 14, 2008 10:13 pm
by Doug_S2
That has been on my car for a few months to test the software and hardware mods we need to run 2 throttle bodies on the standard ecu. I'll be running a dual throttle body manifold in the next few weeks. Would be nice to do it in carbon as well!
Posted: Thu Feb 14, 2008 11:36 pm
by dummi
flash git
Re: RE: Carbon inlet manifolds....
Posted: Fri Feb 15, 2008 9:10 am
by tartan_rob
spen wrote:I'm interested, depending on cost.
Myself and Doug are looking at this next week.
RE Dual throttles, yes we should talk Doug.
Posted: Sat Feb 23, 2008 9:57 am
by ZKNY
Tartan_Rob wrote:spen wrote:I'm interested, depending on cost.
i want in! =D
RE: Re: RE: Carbon inlet manifolds....
Posted: Sun Feb 24, 2008 9:36 pm
by g60bv
this all sounds -SWEET-
rob. keep me informed. also is it not pos to make the apr pipe in carbon. better than crappy ali cast. and probably the same price...
