Anyone had problems with scoring on their RS6 discs?
Posted: Wed Feb 06, 2008 11:17 pm
by Blue_Thunder
I've got the RS6+ front brake set up on the S4.
Noticed the other day that there appears to be some scoring (about 1mm deep) on one of the discs above and below where the pads touch, however the pad I can see doesn't look too bad (is this bit circled red the pad or just part of the caliper? Hard to tell from the photo).
Has anyone else had this? Is it anything to worry about or is it fairly normal?
RE: Anyone had problems with scoring on their RS6 discs?
Posted: Wed Feb 06, 2008 11:31 pm
by grizz
Yep i do , i get mine skimmed when i change pads . The last set of have fooked the discs ..
Posted: Thu Feb 07, 2008 12:39 am
by Blue_Thunder
Is that the pad that i've circled in red? Looks like there's still plenty on that if there is, so wouldn't expect to see so much scoring, especially after only a few hundred mostly motorway miles.
Posted: Thu Feb 07, 2008 10:46 pm
by Doug_S2
you probably got a stone caught in the pad.
Posted: Fri Feb 08, 2008 1:10 am
by flashyg
This patten is caused by the heat stress. it is normal for discs which have reached temps above the norm. The patten is caused by the surface gong into a slightly More fluid state at high temp and then the metal shifts into this patten separating to very high temp points.
Sorry: edited to say i totally misread your question and was explaining the vinyl look.
