Most Power From A K04 Turbo
Posted: Fri Jan 11, 2008 9:39 pm
by Chubby
Can anyone give me max bhp figures on K04 turbos, standard or modified with all other engine mods (intercoolers etc).
I have heard that standard turbos are good up to 490bhp and some conversions up to 580bhp....
Anyone know different or can confirm?
Regards,
R.
RE: Most Power From A K04 Turbo
Posted: Fri Jan 11, 2008 11:12 pm
by Nige_RS4
Rich, you can probably get 1000bhp out of them (for just a few minutes), so the answer depends on how reliable you want your car to be (bearing in mind the cost of replacing those puppies!)
Posted: Sat Jan 12, 2008 11:27 am
by BRETTCOLLINS
My car is running Standard K04's and makes 500bhp, they have been on the car nearly 3 years now and done about 17k. still running better than ever
Posted: Sat Jan 12, 2008 11:35 am
by dazzer
500hp must be on the outer limits of the K04. Depends how often you like to be giving it full boost.
Posted: Sat Jan 12, 2008 12:06 pm
by BRETTCOLLINS
As much as possible, LOL. Car does about 6k a year. think the water injection helps lots...
Didn't aim for 500bhp was after 400bhp, but after fitting the brand new engine and a large box of custom bits, MRC set it up. The car ended up here 501bhp
Posted: Sat Jan 12, 2008 5:18 pm
by Chubby
And these are standard k04's?
What other mods to induction side, it looks like you have a very large FMIC - which water injection are you using?
R.
Posted: Sat Jan 12, 2008 10:30 pm
by BRETTCOLLINS
this is the intake system that my car is running
http://www.sdr-research.com/x1/intake.htm but running the biggest ITG cone filter with it.
car is runnig a RS4 MAF too
the water injection kit is the Aquamist 2D kit.
Posted: Mon Jan 14, 2008 10:09 pm
by Chubby
BRETTCOLLINS wrote:this is the intake system that my car is running
I have the same but with 630cc injectors with upgraded fuel pump, Aquamist running 50 /50 meth - but was getting nothing like that (467bhp @ 6500rpm - could be the FMIC that makes the differance.
I now have hybrids, tubular manifolds as well, lets hope I see the right side of 500bhp when its tuned or the dummy is being spat out...
Thanks fo the info guys.
R.
Posted: Mon Jan 14, 2008 11:02 pm
by jeffw
Mine is running Hybrid K04s, Ported and polished head, cast exhaust manifold, full milltek with 100cel cats & FMIC and it makes 528BHP according to the paperwork I have. This is an MTM conversion. Gives you an idea.
Posted: Tue Jan 15, 2008 12:49 am
by BRETTCOLLINS
Chubby wrote:BRETTCOLLINS wrote:this is the intake system that my car is running
R.
my car also has Custom compression dropping Headgaskets (8.2:1 CR) and the exhaust is custom made from turbo's back.
Posted: Tue Jan 15, 2008 7:13 am
by jeffw
Mine has lower compression as well.
Posted: Tue Jan 15, 2008 2:17 pm
by viperbl
Mine has hybrid KO4's, no engine work except ceramic coated stock RS4 exhaust manifolds, it also has MRC FMIC, larger injectors running on a miltek exhaust and downpipes with no cats. I am running around 550bhp
Posted: Tue Jan 15, 2008 10:39 pm
by S4
viperbl wrote:Mine has hybrid KO4's, no engine work except ceramic coated stock RS4 exhaust manifolds, it also has MRC FMIC, larger injectors running on a miltek exhaust and downpipes with no cats. I am running around 550bhp
someone said the RS4 manifolds are the same as the S4 ones, is this true?
Darren
Posted: Tue Jan 15, 2008 10:41 pm
by MarkB
S4 wrote:viperbl wrote:Mine has hybrid KO4's, no engine work except ceramic coated stock RS4 exhaust manifolds, it also has MRC FMIC, larger injectors running on a miltek exhaust and downpipes with no cats. I am running around 550bhp
Darren
Yes they are.
