B7 brake conversion
sherpa
B7 brake conversion
Post by sherpa » Sat Nov 10, 2007 1:15 pm
Ive just bought new B7 discs, pads and calipers to replace the original front brakes on my B5 RS4.
My dad and i are doing the swap next weekend and just wondered if we need any other parts other than the above?
Blue_Thunder
RE: B7 brake conversion
Post by Blue_Thunder » Sat Nov 10, 2007 1:41 pm
There's a sticky in the B5 RS4 forum on this.
sherpa
Post by sherpa » Sat Nov 10, 2007 1:50 pm
Thats for an RS6 upgrade and there is a difference in discs mainly.
Just wondered if i need anything else in the kit.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Nov 10, 2007 6:54 pm
Think about what you plan to do with the brake hoses.
Some people say you can "stretch" them, but I just did mine yesterday, and I wouldn't want to stretch any brake hose! It's your brakes FFS! I used the other option of using RS6 brake hoses.
I also had to ever so slightly trim the back plate at the bottom, as the caliper was catching it again ever so slightly. Any tin snips will be appropriate for the job.
Also make sure you re-bleed them again after bedding them in, or using them, as they somehow accumulate air again! You'll see it when you open the bleeding nipple! I can't remember but you may need to adjust the hose bracket behind the caliper slightly
Apart from that its all straight forward. I guess your using B7 discs?
Might aswell change the brake fluid in the whole system while your at it.
Virdee Autos ~ 07950-526592
dhali
Post by dhali » Sat Nov 10, 2007 7:09 pm
while your at it go for the phaeton cooling ducts aswell. At only 60 odd quid .
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Nov 10, 2007 7:30 pm
Are they really beneficial for road use?
dhali
Post by dhali » Sat Nov 10, 2007 9:07 pm
im sure i read somewhere that they help reduce the wear on the inside of the disc, whether that is true i dont know. And as for beneficial for road use, must be there for some reason on the phaeton as you dont see any on the track :lol:
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Sat Nov 10, 2007 9:41 pm
Hmmm goind point!
Is there some sort of duct like this on the RS4/6? If not, then you'd more likely to see one of those on the track than a Phaeton!
