Transmission Stabiliser Question.
Posted: Sat Oct 27, 2007 11:53 am
by Silversea
Can some of you guys explain the benefit of fitting a transmission stabiliser please? What does the driver experience that justifies fitting one?
My mate has an S4 and was thinking his clutch plate was damaged, he said that he gets a slight vibration when pulling away hard in first gear and also mentioned that the gear stick has a bit of travel at the same timeā¦.
Thanks in advance!
RE: Transmission Stabiliser Question.
Posted: Sat Oct 27, 2007 5:14 pm
by quattrokid1
Helens RS4 sometimes takes a bit of a push to engage first gear but as the clutch pedal comes up in drop into gear.
The stabilizer just makes the tranny stiffer in its mounts reducing the effect of the engine's torque as it is channeled down the propshaft.
About the DTS
Posted: Sat Oct 27, 2007 5:25 pm
by quattrosteph
The DTS will stop the engine and gear box to travel too much forward and backward when changing gears or when on and off the power, it will make gear changes easier as well. It is a really good piece of kit, very easy to fit. I have one on my car and the difference was obvious.
RE: About the DTS
Posted: Sat Oct 27, 2007 6:51 pm
by quattrokid1
so what do you need to alter to attach the stabilizers or does it bolt straight on quattrosteph?
thanks
Posted: Sat Oct 27, 2007 7:22 pm
by TopBear
You just remove the old plate, and install the DTS in its place.
Rich, this was one of my first mods and really makes a difference to the 'slop in the box'.
Posted: Sat Oct 27, 2007 8:50 pm
by Silversea
Thanks for the expaination!
